Air intake on undercarriage? | Ford Explorer - Ford Ranger Forums - Serious Explorations
efitz
Herndon, VA
2013 Ford Explorer Sport
I have a 2013 Ford Explorer Sport.
Recently I pulled up too close in a parking space and ran the front bumper cover up onto the curb.
As a result I dislodged an air intake of some sort. The intake is slightly off to the right side of the vehicle.
What is this air intake for?
Do I need to get it repaired?
Why is there an air intake 6" off the ground on an SUV? What if I drove through a deep puddle...
broken strut
CHIMOMAN VILLE
2013 White Sport
That's to cool down the engine when towing.
broken strut
CHIMOMAN VILLE
2013 White Sport
If you intend on towing anything get it fixed.
langla4
Fullerton CA
2013 Explorer Sport
It is a simple repair as it is held to the undercarriage with three thumb screws. You can do it yourself if you raise the right side of the Sport. Btw, this has to be removed with every oil change if you drain the oil from the bottom.
efitz
Herndon, VA
Awesome, thanks guys!
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
It seems that all the 2013 Sports have this intake whether they have the towing package or not. Must have something to do with the Ecoboost engine cooling.
Harley#356
NJ
2013 Explorer Sport
follow the channel....it goes to the rear turbo to help cool it since it's nestled back there pretty good.
dodgers1
Conroe, TX
2013 Explorer Sport
Just noticed this air intake part was loose on my 2013 Explorer Sport. Recently had an oil change at a Jiffy Lube type place. (These same guys told me that if I didn't use a synthetic blend oil that Ford would void my warranty, which I'm sure is BS.) I suspect they failed to tighten it properly, although I can't tighten it by hand. Any thoughts?
peterk9
Staff member
Moderator
Callsign
VE3
Welcome to the Forum dodgers1.:wavey:
I always have the dealer do my oil changes although according to a few posts, they have also allegedly been guilty of not tightening the defector properly.
A synthetic is recommended but not mandatory. As long as you use an oil that meets Ford's specs. I believe that is covered in the Owner's Guide. My dealer puts regular premium oil in my Ecoboost engine. As for the deflector, it is a very important part of the turbo cooling system.
dodgers1
Conroe, TX
2013 Explorer Sport
Thank you for the info. I'm going to see if the oil change place can tighten the screws. It's tough to get under there without a lift. My original dealer is quite a journey from where I live. It's still under warranty, so maybe I'll go to the local dealer who was not very helpful during my purchase experience.
1995E
Maryland
95 + 11 Ex both XLT
They are partially right. The new engines take semi-synthetic blend oils and no longer use the conventional oil. They come stock with the synthetic blends from the beginning.
Also, I'd avoid changing your oil at Jiffy Lube. They are known for their scams, etc in some parts of the country.
My air intake fell when i went over a speed bump because the person changing my oil decided to tighten it by hand instead of by tool. It's pretty tough though and snapped back on. Thank goodness it was just that and not a broken suspension part of the car lol.
Natedogggg
Brandon
2015 sport exolorer
Have a link to buy these thumb screws?
peterk9
Staff member
Moderator
Callsign
VE3
Toddman41
Herculaneum, MO
2019, Explorer Limited
These come on all motors. My 19 is the 3.5 NA and has the light metal duct on the passenger side under the motor.
1st time I noticed the cutout on the lower air damage, I thought a plastic trim piece had fell out. When changing the oil I realized it has a purpose.
peterk9
Staff member
Moderator
Callsign
VE3
Not actually so. They are on Explorers with Ecoboost motors and those with the factory tow package. My 2011 did not have one.
Toddman41
Herculaneum, MO
Mine has it, no Ecoboost. But tow package, so
ecoboost_xsport
Mad Scientist
Orangevale, California
2015 Ford Explorer Sport
It is designed to channel air to the cooler for the PTU as well as the rear catalyst/turbo area as it can get pretty hot back there.
Pics for anyone interested:
JBumgarner
Florence
2016 Explorer Sport
My 2016 sport with tow package has it. I just accidentally pulled it off by pulling to close to a parking barrier.
peterk9
Staff member
Moderator
Callsign
VE3
^^Welcome to the Forum. :wave:
