mustanglover32
- November 2, 2007
- Sacramento, CA
- '98 Explorer EB 5.0 AWD
Okay, so when I first got my 98 AWD Ex, I quickly realized that the ARC was crap. The shocks constantly leaked, or sometimes they didn't. Sometimes it had a gangster lean sometimes it didn't. I looked into replacing them, only to discover that they were extremely expensive. I knew from my previous encounter with Ford's ARC on my 88' TurboCoupe (no, not a Thunderbird, a TurboCoupe!) that you could simply switch out the ARC for regular old shocks.
HOWEVER.....
I had my EX in the off-road mode (which is supposed to initiate the ARC, and provide the vehicle with an extra 3-4 inches of lift or so I am told). Normally, due to the aging/leaky shocks all the off-road switch did was firm up the ride on bumpy roads. On this particular day, I pulled up to the front of my house and left my EX running, unloaded a few things and walked to the backyard leaving the rear hatch up.
When I returned, the rear of my EX was at least 1-2 feet higher!! The ARC system had gone into overdrive!! When I walked up to the rear of the truck, the bumper was ABOVE MY WAIST!! I had to take a running jump to close the rear hatch because it was way up in the air (and I'm 5'9").
Man do I wish I had taken a picture of that. But it has only done this two times in the past year.
Ok after all that here is my question:
Was the ARC system ever designed to lift my EX up that much? Is there a way I can set the height level myself? Are the front shocks capable of 1-2 feet of lift as well or was this just a freak incident by the ARC gods, trying to make me think I had a something nearly as useful as a full lift kit costing in the thousands?
In my opinion if the ARC system is capable of giving me 1-2 feet of additional clearance just by flipping a switch, the I will spend the money to replace the entire thing tomorrow. In the end that ARC system works better for me than a traditional lift kit would.
Any ideas?
Thanks,
David
HOWEVER.....
Any ideas?
Thanks,
David
