Airbag Codes | Ford Explorer - Ford Ranger Forums - Serious Explorations
Airbag Codes
Treleaven
Edmonton, Alberta
1997 XL
Air Bag Fault Code Table
AIR BAG DIAGNOSTIC MONITOR FAULT CODE PRIORITY TABLE
Priority Code Component/Fault Description
Highest --
No Air Bag Lamp - Inoperative Lamp Circuit or No Ignition Voltage to Diagnostic Monitor
| -- Continuous Air Bag Lamp - Diagnostic Monitor Disconnected or Inoperative
| 12 Low Battery Voltage
| 13 Air Bag Circuit or Crash Sensor Circuit - Shorted to Ground
| 21 Safing Sensor - Not Mounted on Vehicle Properly
| 22 Safing Sensor Output Circuit - Shorted to Battery Voltage
| 23 Safing Sensor Input Feed/Return Circuit Open
| 24 Open in Circuit 944B or Low Resistance in Crash Sensor(s)
| 32 Driver Side Air Bag/Safing Sensor Circuit - High Resistance or Open
| 33 Pin 7 Not Grounded at Diagnostic Monitor
| 34 Driver Side Air Bag/Safing Sensor Circuit - Low Resistance or Shorted
| 35 Low Resistance Across Pins 8 and 9 at Diagnostic Monitor
| 41 Crash Sensor Circuit - High Resistance or Open
| 44 RH Crash Sensor - Not Mounted to Vehicle Properly
| 45 Center Radiator Crash Sensor - Not Mounted to Vehicle Properly
| 46 LH Crash Sensor - Not Mounted to Vehicle Properly
| 51 Diagnostic Monitor Internal Thermal Fuse - Blown and Short to Ground No Longer Exists
| 52 Backup Power Supply - Voltage Boost Fault
| 53 Internal Diagnostic Monitor Fault
Lowest -- Rapid Continuous Flashing of Air Bag Lamp - All Crash Sensors Disconnected
Join the Elite Explorers $20 Get rid of the ads!
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
. First register on the forum, then join the Elite Explorers to get rid of the ads!
Treleaven
Edmonton, Alberta
1997 XL
I am getting a code 52. Where would I find my backup supply and how would I fix this?
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
B29FE
Bixby, Oklahoma
96 XLT
Airbag Fault
2002 Ranger, Airbag Fault Code of 46, Where is the Left Crash Sensor Located?
Thanks
Steve
little x
SW VA
'91 XL
My father's 01 is flashing code 37.
Anyone know what it is, or where I may find an answer. I've searched, but haven't come up with anyone else throwing this same code.
Fast Edit: Code 37 is the passenger side side-airbag, often caused by a bad connection in the yellow resistance cap under the seat.
ncranchero
Co-moderator
Moderator Emeritus
Denver,NC
1997 F150 XLT 4x4
FYI, these codes vary somewhat year to year.............
356
99 Explorer 4x4
... Code 37 is the passenger side side-airbag, often caused by a bad connection in the yellow resistance cap under the seat.
That is why these forums are so great...I was throwing a Code 37, and the solution was simply unplugging and replugging the yellow cap under the passenger seat!
Equnoxe
Ontario
97' Exploder EB Edition
code 12, but batteries are all good and connections are good?
BrooklynBay
Staff member
Moderator
Brooklyn, NY
Equnoxe
Ontario
is the battery replaceable or do i have to replace the whole module? and you know were it is?
thx
BrooklynBay
Staff member
Moderator
Brooklyn, NY
The battery is inside of the air bag module. Check the wiring going to the module first. Maybe the module isn't getting the correct voltage or there might be a problem with the ground wiring? You will need a pin out schematic of the module before you begin to troubleshoot. Use extreme caution whenever you work on the SRS wiring. You don't want to deply the air bag.
Equnoxe
Ontario
OK thx, ill just grab a diagram from work. don't want those puppies going off :D
Lil Blue
Burke, VA
2004 Sport Trac XLT
Can anyone tell me what airbag code 19 means for an 04 spt trac? Thanks,
ncranchero
Co-moderator
Moderator Emeritus
Denver,NC
1997 F150 XLT 4x4
B2293 19 Restraint System — Air Bag Status (Driver Front Air Bag Circuit Fault)
Lil Blue
Burke, VA
2004 Sport Trac XLT
Thanks, I finally got the correct problem identified for the airbag. I changed the sensor on the master cylinder as instructed by this forum. That resolved my issue with the cruise control, but the airbag light did not go off. I have a powered seat. I then took the driver seat off (4 bolts). I unplugged, cleaned and replug the three circuits under the seat. That worked until I made adjustments to the seat. The light returned. Unplugged each circuit individually. The culprit is the two wire circuit on the left side of the seat. Recleaned and replugged, it is working at the moment. I hope to get the car inspected tomorrow.
ncranchero
Co-moderator
Moderator Emeritus
Denver,NC
1997 F150 XLT 4x4
Hope it works but that's not what the code says if it was 19. Stranger things have happened though.
Keno Biebrich
Hermosillo, Sonora, Mexico
2005 Explorer XLT 4x4Utah
este es mi codigo.... como resuelvo este problema?
