Airnag warning lite
Mickalo
Location
NW., Iowa
Iowa
2010 Explorer w/4.0 4wd
Got hit with a major cold snap this am about -25F air temp this am. She started up no problems .. but for some reason now the yellow air bag yellow warning light stays on, no flashing or blinking light, just stayed on. Is this common in extreme cold temps ? I checked under the seat the wiring harness looked ok nothing under seats that would trigger light Is there a trick to reset the warning light if it doesn't shut off ?
TIA
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
Zorin
Milton, KS
2006 Explorer Eddie Bauer
Mine did this ONCE. I drove it to work with the light on, figuring I'd pull the code after work. Restarted it at lunch, light on for the six second self check, then went out.
Still unsure what caused it, only thing I can guess is lower than normal battery voltage while cranking took the module offline.
Tim
Mickalo
Location
NW., Iowa
Iowa
ok that make sense about the battery voltage didn't think of that. it crank really slow but started so could have been that. Will be out later today to pickup my daughter at work will see if it goes out now.
Thanks,
Rcflyer330
Michigan
2010 Ford Explorer XLT V6
There is a stored code if you have a obd2 scanner that will do airbag codes then you can get it. The airbag light will come on if your battery is going bad due to the low voltage while cranking. If your battery is around 5 years or older its time to replace it even if the car started. If the battery is newer then have the battery tested at your local autoparts store. To remove the light and the code you need a scanner. I had the same problem car would start fine but the airbag light came on (its was in the negitives outside) i pulled the code and it was for the passenger seat sensor. I went away for the holidays and came back and the battery was dead replaced the battery and eased the code and have had no problems since.
Mickalo
Location
NW., Iowa
Iowa
the battery is only a few months old Napa 850 CCA battery this morning is the only time it actually crank really slow. The last few days we've been averaging -15F below in the morning. Haven't had any problems till this morning the coldest I can remember in a very long time.
Mickalo
Location
NW., Iowa
Iowa
started it up this afternoon and the airbag light went out like it suppose too after startup now. Guess it was the extreme cold this am. thanks for the help
tripplec
Bowmanville, ON Canada
2009 Explorer LTD AWD
At that CCA rating it should have turned over much better and not dropped that low to cause problems. Battery maybe faulty and checking it while under warranty may be a smart move.
H "OIL CHANGE REQUIRED" warning & sluggish engine respond Stock 2006 -2010 Explorers 3
S RR,LR,Lampa and he front two lamps are giving me a warning..hazard Stock 2006 -2010 Explorers 1
S 2006 Ford Explorer xlt tire sensor warning Stock 2006 -2010 Explorers 2
S Lamp warning Stock 2006 -2010 Explorers 0
B Tire Fault Sensor Warning Light Stock 2006 -2010 Explorers 10
S Can Dashboard Warning Lights Be Checked? Stock 2006 -2010 Explorers 7
W SRS (airbag system) warning lamp - reset after repair Stock 2006 -2010 Explorers 2
R Battery Warning Light Flashes Occasionally Stock 2006 -2010 Explorers 2
U Gauges Die, Warning Lights On, Truck Runs Fine Stock 2006 -2010 Explorers 0
M Can Worn front wheel bearing trigger ABS and traction control warning light? Stock 2006 -2010 Explorers 2
X 4th gen Explorer red oil warning light comes on at low idle? Stock 2006 -2010 Explorers 5
R 2008 4.0 v6 throttle/idle adjust? orange warning light -wrench P2104 P2112 errors Stock 2006 -2010 Explorers 0
P Alternator not charging /charging system warning Stock 2006 -2010 Explorers 11
L Warning lights - 2009 ford explorer Stock 2006 -2010 Explorers 5
K Fuel Filler Tube Warning Light Stock 2006 -2010 Explorers 2
M Passenger seat air bag warning? Stock 2006 -2010 Explorers 0
L High Oil Pressure Warning, total loss of Power, some hard shifts 08 Stock V8 Explorer Stock 2006 -2010 Explorers 3
R warning lights, dash problem, alternator fixed it Stock 2006 -2010 Explorers 4
S ABS Code B1342 - ABS light and TCS warning (traction control) Stock 2006 -2010 Explorers 17
D 07 Explorer 3 Dashboard Warning lights not Working Stock 2006 -2010 Explorers 2
L Dash warning lights all coming on randomly Stock 2006 -2010 Explorers 29
M Service rsc now warning light Stock 2006 -2010 Explorers 16
B Warning from tranny? Stock 2006 -2010 Explorers 1
B Air bag warning lite on dash display? Stock 2006 -2010 Explorers 10
P Low Brake Fluid Warning! Stock 2006 -2010 Explorers 0
E Warning - sparkplugs on v8's, recoating with nickel anti seize. Stock 2006 -2010 Explorers 2
K 2007 Explorer Front Seat moves without warning Stock 2006 -2010 Explorers 9
M Help - Multiple warning lights Stock 2006 -2010 Explorers 1
M All warning lights on! Stock 2006 -2010 Explorers 4
A Wise Guy Redline Temp Guage Warning Stock 2006 -2010 Explorers 22
S Loose Gas Cap Warning Light Stock 2006 -2010 Explorers 2
M resetting the oil change warning on the computer. Stock 2006 -2010 Explorers 25
M All the warning lights came on. Stock 2006 -2010 Explorers 2
A HELP!!! Oil change warning Stock 2006 -2010 Explorers 3
D warning light Stock 2006 -2010 Explorers 5
B Airbag, ABS and Advantrac lights along with repair RSC NOW warning message Stock 2006 -2010 Explorers 2
K 2006 ltd, door ajar warning Stock 2006 -2010 Explorers 0
edwx Powertrain/4x4 warning light? Stock 2006 -2010 Explorers 4
M 2006 ford explorer clearing warning messages Stock 2006 -2010 Explorers 1
T ABS Warning Lights Stock 2006 -2010 Explorers 3
S Coolant Temp Warning Light Stock 2006 -2010 Explorers 5
C Warning Lights - ABS Brake "wrench" and slipping car all on Stock 2006 -2010 Explorers 16
D How to: Reset the oil change warning light. Stock 2006 -2010 Explorers 11
S ELM327- FORScan lite connection issue solved Stock 2006 -2010 Explorers 1
R Timing the 4.6 lite 3 valve - timing work. Stock 2006 -2010 Explorers 2
R Help with aftermarket auto headlights Nite Lite 545T Stock 2006 -2010 Explorers 13
J installed new radio now air bag lite on Stock 2006 -2010 Explorers 5
Similar threads
