AlaskanJack
Elite Cabin-Fever Captain
- March 24, 2002
- Centralia, Washington
- 91 , 93 & 01 Sports
Oh I had read that with the solid axle low pinion and at full flex the driveline angle would bind and cause problems. My chief concern was the front because it is so much shorter than the rear. My current rear driveshaft will more than likely work and need to be cut down since its not a stock shaft. My front shaft will definitely need replacing
I was going to swap out the pinion yokes to match the 1310 ujoint set up currently run.
But I do hear what you are saying. I could keep the shafts and use the yokes to match up with the axle end of the shafts.
So no mention was made of the radius arms and drop brackets. I am planning on using the ones off the EB or maybe getting the Wild Horse ones with the adjustable Caster I saw another person use. But then I also plan on checking into the price on a 4 link set up and see how much that would be. I have a local fabricator that is supposed to get back to me on a price. He also just happens to be the same guy that makes everyones hydraulic steering components and rocksliders.
