beavis195
- October 15, 2000
- Sammamish, WA and Provo, UT
- 94 XLT 4 door
Hey just had it aligned again and it still pulls right a little bit but not as bad as it was. The steering feels better too so thats good. but Here is what the printout says
Left Front
Camber: -0.7
Caster: 5.0
Toe: 0.10
Right Front
Camber:-0.3
Caster: 5.4
Toe: 0.12
Total Toe: 0.22
Steer Ahead: -0.01
Left Rear
Camber: -1.5
Toe: 0.24
Right Rear
Camber: -0.7
Toe: 0.04
Total Toe: 0.28
Thrust Angle: 0.10
A few questions. because the camber is more positive on the right side, doesn't that cause the vehicle to steer to the right? Why did they set it there?
And on the rear why is the camber and Toe so extreme on the left side compared to the right side. I saw that they had like three guys looking at it and then the guy grabbed some vice grips so maybe a stuck bolt but dunno. I did have to get pulled out of snow and the chain was wrapped around the axle type thing on the left rear side so did something bend and they weren't able to tell? Anyway, can someone please help me figure this out? I got so lucky with my 94 it was tracked straight and turned easier than any car I've driven. This '05 hasn't been so lucky but hopefully we can get it that way.
Thanks guys!
Left Front
Camber: -0.7
Caster: 5.0
Toe: 0.10
Right Front
Camber:-0.3
Caster: 5.4
Toe: 0.12
Total Toe: 0.22
Steer Ahead: -0.01
Left Rear
Camber: -1.5
Toe: 0.24
Right Rear
Camber: -0.7
Toe: 0.04
Total Toe: 0.28
Thrust Angle: 0.10
Thanks guys!
