Alignment Issue - Help!! | Page 2 | Ford Explorer - Ford Ranger Forums - Serious Explorations
yavapaires
Dewey, Az
1996 XLT
Doubt that would be the case, the tires were put on (new) right before the alignment was done.
Took it back to the shop, and they can still only get it to .10. :fire:
You can't count out new tires not having a separation, or some other problem. Had 89 Peterbilt with new Michelins on the front, pulled constantly to the right, Between 5&6 thousand miles and blew right front. Try switching the front tires and see what happens. Easy to do, and will tell you if it is the tire or something else. And, why would you need more than .10 of toe in? .10 is 100thousandths of an inch, .125 is 1/8th of an inch. Or are they talking degrees? I'm sure, if I really wanted to, I could get at least 1/2 inch of toe by adjusting the outer tie rod ends. But, seriously, .30 of toe in is way too much, if measured in inch, don't know how much that would be in degrees.
