Alignment problems (Superrunner Steering?) | Ford Explorer Forums - Serious Explorations
Blaine122300
Elite Non explorer owner
Tucson, AZ
1997 Land Rover Disco
I am having a tough time keeping my rig aligned. If I get the superrunner steering linkage, will this help alleviate this problem? I can't seem to get the toe set right. One day, it will pull to the left, I'll adjust it a little (very little) then it will pull to the right. I would like for this to stop. I know that the superrunner steering is set up a lot better than stock, but will it solve my problem? any help apprecieated.
Andy
Sho do. Its just a pain to keep aligned!
I had troubles for awhile too because the springs started to settle and man does that hurt the camber... I'd say take it to Firestone, get the lifetime alignment deal, and just keep taking it there till it doesn't pull anymore :D
will the super runner steering help?
honestly, i don't know, i'm not running it...still completely stock steering pretty much, save the pitman arm. i think mattadams is though, so you could try pm'ing him and see if he thinks it helps the alignment problems.
The steering won't solve camber issues. Thats all springs and camber bushings.
It may help the toe issues as it keeps the steering links almost parallel to the ground and it will certainly almost eliminate bumpsteer.
simple solve for this......... lifetime allignment plan at firestone. and make sure you got the camber adjustment bushings.
Thank you everyone for your help. I got all the info I needed.
Andy
Firestone has a lifetime alignment deal? How much is this? Is it limited to running firestone tires?
