toddious
- December 27, 2003
- winter park, FL
- 1996 Limited 4x4
i have a 1996 Limited, so it uses the air ride system. does the different air ride settings effect the alignment at all? so if i am using the 4auto setting vs. the normal 2wd (so the air ride system rides about 1.5" higher), will the alignment be off? and what about when you replace your shocks, do you need an alignment then? thanks, todd.
