Alignment specs..good, bad, or ugly?
Had the 2001 Ex in for tires today and had them do a alignment check. Curious on everyone’s opinions on the specs, I ended up not having it done because they could not adjust the Camber. The truck does like to wonder a bit, no lift, stock 255/70/16 tires. Should I take it to the dealership? Thanks, the # are….
Front..left
-1.0 (-1.0-0 range) Camber
3.6 (3.2- 5.2 range) Caster
.05 (-.03-.09 range Toe
Front…right
-.4 Camber
4.2 Caster
-.04 Toe
Cross camber -.06
Cross caster -.06
Total toe .01
Mods…wasn’t sure if I should post this here or 1995-2001 stock forum.
Drake
Front..left
Front…right
-.4 Camber
4.2 Caster
-.04 Toe
Cross camber -.06
Cross caster -.06
Total toe .01
Drake
