Almost complete so..... | Ford Explorer - Ford Ranger Forums - Serious Explorations
I have a nasty squeal in the front brakes. I got new rotors and wheel studs. The rotor isn't completely tight against the hub. I've tried to get the studs as tight as possible. I'm just afraid that I'll snap a stud off. Guess I'll keep tightening them up.
BUT here's what I did tonight. Oh who ever said about creaming your jeans in double low.....:exporange
Need to build the xmember before I can flex the drivers side down.
This is whats left in the shocks.
About 2" droop and 3" compression left on the front.
About 2" droop and 1" compression left on the rear.
steventadams
New Jersey
2001 Sport
damn. thats some serious flex you got there. and thats good use of the other truck. you gotta crawl up somethin...
zainyD
Lakeland, FL
'96 Ranger 4x4 XLT
Tuned out great man, nice job!!!
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
NICE! I see a future RC run ! :D Count me in!!
Btw that looks more like a "wristed" radius arm setup (as opposed to 3-link) ;)
FireZapper
Columbia Pa.
93 Sport
Yea some say radius arm some say modified 3 link.
10th is the shakedown and 24th is a run with the Keystone Krawlers.
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
I'm loving those beadlocks. I want beadlocks :(
Are the outer rings coning a bit?
95exploderboy
Locked and Loaded
Annapolis, MD and Lebanon, PA
1995 Sport
Looking good there. Did you notice any binding/angle issues with your rear driveshaft and the Stubler. I got my driveshaft in today and don't think I'll get much drop before I start to bind up.
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL Pumpkin Edition
Callsign
AB7FH
That came out great! Good job:chug:
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
I was thinking the same thing about the 14-bolt (or I guess most low-pinion axles). But one way to get around this of course is to use a double-cardan on the rear driveshaft. That would allow you to rotate the rear axle and point it at the transfer case -- minimizing U-joint angle.
colindo94
Cameron Park, CA
94' XLT
Looks very good. I didn't even know you were going solid. I like your truck a lot.
Iceking007
Edmonton, Alberta
1991 Ford Explorer Sport
Man that is awsome... your rig is cool... what size tires do you have on what wheels?? do you think you might go wider... some of the flex they look skinny?! maybe its just me... I'm wondering were did you get those rocker boards from those are cool??
