Aloha, thanks for reply, I had an 01 ranger4.0 4x4 auto, that got tboned found a 05 sportrac 4.0 2 wheel drive with a blown 4.0 engine, so I put the o1 in the sportrac everything hooked up , used the wiring harness from the 01 cause each connector had a home ,everything works but the starter don’t crank, is there something different about the wiring of the newer sportrac that I am missing? Thanks in advance I am an old guy who thought it would b easy!!! Oh well but I need to get the trac outta my drive for thanksgiving or I will b the only turkey there !!!Dude we need waaaaaaaaaaay more information.
So now what can I do?
Thanks for helpingFirst off well done getting this far
We should be able to make this work
What computer did you use?
The proper way to do an engine replacement with a shock engine is
Pull 04 engine park it on stand or tire or whatever
Park new 01 engine in stand next to it
Strip 01 engine down to heads
Strip 04 engine down to heads
Dress 01 engine to be a 04 engine using all intakes wiring sensors intakes accessories and plumbing
New gaskets and tune up parts Along the way
Basically this way everything on the truck side remains 04 you are simply installing the 01 long block
Working backwards from this is more tricky
Start with the basic questions
You kept the 04 computer and just plugged the 01 engine into it?
Do you have a theft light? Does it flash or go out when attempting to crank?
Need I remove the front wiring harness that goes behind the fan etc, or are we dealing with the rear harness,Thanks for helping
Yes I used the engine and wiring from the 01 just plugged everything in
The theft light is illuminated until u put the key in and try to crank and it disappears,,,I used the o4 wiring which I guess hooked up to the computer,
I have the o4 on a stand and the o1 in the truck already , do I need to change the injection parts? Aren’t they the same?, the black plastic tunnel appears to b identical to the o4 except that there’s a vacuum or exhaust port in the front on the drivers side replacing the bigger one to the rear on the 01 so I used the o1 and plugged the hole,Need I remove the front wiring harness that goes behind the fan etc, or are we dealing with the rear harness,
