dhoisak
- August 1, 2006
- Navan, Ontario
- 2003 EB 4WD 4.6
My alternator fried the other day on my 98 XLT, and I replaced it with a rebuilt 95Amp model. The parts guy said this was the model for an XLT with no power seats, heated seats, rear A/C, etc. I got the alternator installed and all appeared ok. 12.62 Volts on the battery with the engine off and 14.45 Volts with the engine running.
My wife was out driving the day after, and the battery charge light would come on and the battery charge guage would drop down a bit. Seems this only happened on bumby roads. On smooth roads the idiot light would turn off.
Last night I checked the voltage with the engine running.. 13.3 to 13.7 Volts, not 14.5.. cranked up the A/C, turned the lights on, hazards flashing, music playing and it dipped to 12.9 to 13.2 volts and the idiot light came on again.
I turned everything off, disconnected the battery, reset all the connections on the alternator, checked the grounding, checked the continuaty of the 175 Amp MEGA fuse and other large fuses, all were ok. Reconnected the battery, started her up, and 13.7 to 13.8 Volts. This morning my wife's driving it and the idiot light is on all the time
Do I need the 130 Amp Alternator? What else should I check?
Thanks
Thanks
