filteredsoul
- January 19, 2011
- Asheville, NC
- 2004 XLT
Hi everyone,
First of all, a big thank you to all who have helped me with my various troubleshooting issues over the past few years! You have saved my wife and I TONS of money.
We own a 2004 Ex XLT with the 4.0 V6. It's got the funky transmission, but thanks to you I've replaced the rear wheel bearings, sway bar links/bushings and replaced the blend door actuator. That's a ton of money saved right there! My latest issue seems to be electrical. My wife was driving to work the other day and noticed that the battery light came on when she pulled out of our subdivision. It's kind of a blind corner so she got on the gas a little harder than normal. She thought the battery might be loose because of turning the corner hard. When I checked it, all was good. The next test was to point it straight and nail it. Sure enough, at around 4k the battery light came on (and stayed on as the rpm's increased) Below 4k everything seems fine. I read all the posts about battery lights flashing and it seems the alternator may be the culprit. Possibly the regulator not being able to regulate the higher voltage? I took it to Advanced auto for them to check and everything checked out ok... but they didn't have the ability to check the amperage. NAPA didn't either so I may call around to see if there are any shops that can.
To throw in another variable, I just got the oil changed today and they said the serpentine belt was getting to the end of it's life. It's the OEM belt with 106k miles on it. Visually it looks ok, but they're probably right. Wondering if a worn belt could be adding to the problem?
I'm still thinking it's the alternator... any other ideas or ways for me to check anything else?
As always, THANK YOU in advance!
Dan
Dan
