pyxis
- August 21, 2007
- Detroit
- '97 XLT
I'd appreciate some help diagnosing this problem with my 97 Explorer. First time I started the truck up today, it cranked a little slow but started up. I should of known something was wrong by the way it started up but I decided to ignore it and pay to tow her home later
Later on when I tried starting it up it would make just one click and not do anything else. I took the battery out and had it tested. It turned out ok. I looked over at the alternator and noticed that the wire look a little melted. Looked closer and saw that the whole post had melted off and fused everything together. I pulled the whole post out without any tools and everything just crumbled apart.
I think the wire got loose on the terminal and it arced causing everything to char and eventually melt.
Well I replaced the alternator and tried starting it up but it still makes only one clicking noise and nothing else. I think the alternator might have damaged some other components. I'd like some suggestions on what to check out. Could it have fried the starter? Or maybe the solenoid?
Thanks
Thanks
