Jobert
- August 25, 2015
- New Jersey
- 2002 Explorer XLT V8
My 2002 Explorer 4.6 V8 alternator is suddenly not putting anything out. It's apparently been this way for about a month or so but hasn't been a problem since I have been keeping the battery charged since I found the problem and don't use it at night, etc. I have other transportation available.
My question is: Should I be checking anything before I just go out and buy a new alternator?
I'm very much mechanically inclined and if you check my relatively few posts you'll see that I purchased this ride last August with a spark plug blown out (and a prior helicoil repair that didn't hold) which I repaired shortly thereafter and which has been fine ever since (knock wood). So any suggestions on testing the alternator would be welcomed and much appreciated.
I did search the forum but didn't find anything helpful so far, so I figured maybe I should just ask.
Edit (update): Well, since I posted, I saw some "similar threads" with suggestions, so I'm checking those out. Also, I have to check but I think that my charging gauge is indicating that the battery is charging. I actually never really checked it but I live in NJ and it's been quite cold at times so I warm it up well before driving it and check the oil pressure in particular when I first start it. I believe the alt gauge is right next to the oil pressure and I think it shows it charging. I'll check and update accordingly. Also, I don't think I have a warning light if it's not charging, but if I do that has never come on. But I know it's not charging because I check the battery terminals for voltage when it's running and only get 11.5 volts, if that. Plus I only found out about the problem when the battery was too dead to crank it one morning. And it got so low that my trip odometer reset to zero.
