Alternator or starter???
sasha
Avondale AZ,
2003 ford explorer
Went to start truck yesterday (03 Ford Explorer XLS 4x4) and it just clicked and clicked. Charged the battery so I know it's not that. How do I know if it's the alternator or the starter? Is there a way to tell?
Thanks in advance for your help.
gmanpaint
It's Always Something!
Staff member
Moderator
MO MO
94 & 95 XLT's
Why did you have to charge the battery?
If the alternator is doing its job, the battery will be charged, unless it sat for prolonged amount of time. If not, the engine running will drain it fairly quick.
Do you have access to a multi meter? If the battery has about 12.5v charge to it, and the cables are good, and you hear a clicking noise from the starter when turning the key, it could be the solenoid on the starter that's bad. Does all the interior lights, radio, etc work alright?
If the battery and starter are good, then the power isn't getting to the solenoid. That could be a loose cable connection or a bad cable.
If the alternator is good, it will read about 14.7v at the battery when engine is running. But since you can't tell that right now, it needs bench tested to confirm.
First check all your cables for loose connections, corrosion, breaks. If good.... time to remove the starter and bench test it, then the battery, then the alternator. Most parts stores will do this for free. If all test fine, then a bad cable is suspect from inner corrosion.
sasha
Avondale AZ,
2003 ford explorer
I charged the battery just to make sure it wasn't that.
Thank you for your reply. We are going to be working on it tonight.
J Bad Alternator or could something else cause this? Stock 2002 - 2005 Explorers 1
B Alternator Shocker Stock 2002 - 2005 Explorers 17
T Faulty Alternator. Can it cause shift problems Stock 2002 - 2005 Explorers 2
D Alternator not failing but... Stock 2002 - 2005 Explorers 3
C Alternator Stock 2002 - 2005 Explorers 1
2 Bad Battery or Alternator or Both Stock 2002 - 2005 Explorers 12
C 2005 Alternator Mystery at Exciter Wire Stock 2002 - 2005 Explorers 0
M 4.0L Alternator Question Stock 2002 - 2005 Explorers 14
C Mega Fuse or Alternator Issue? Stock 2002 - 2005 Explorers 11
Z 2005 Explorer Alternator ? Stock 2002 - 2005 Explorers 6
9 Alternator Issue - faulty voltage regulator Stock 2002 - 2005 Explorers 3
M Solved Alternator issue. Stock 2002 - 2005 Explorers 6
J Alternator not charging Stock 2002 - 2005 Explorers 21
F Alternator for 3rd Generation V6 Stock 2002 - 2005 Explorers 4
L Those with the squeaking Alternator pulley.. Stock 2002 - 2005 Explorers 5
M 2003 Explorer Noisy Alternator Stock 2002 - 2005 Explorers 21
4 Can my alternator handle this? Stock 2002 - 2005 Explorers 7
D 2004 Explorer 4.6 alternator CHAOS (long post) Stock 2002 - 2005 Explorers 5
C Computer Test Mode After New Alternator and Battery Stock 2002 - 2005 Explorers 3
Number4 '05 4.0 Alternator issue - at a complete loss Stock 2002 - 2005 Explorers 7
R What is proper voltage for alternator to be outputting? Stock 2002 - 2005 Explorers 8
D 2005 Alternator Stock 2002 - 2005 Explorers 1
B Alternator bolts shearing off? Stock 2002 - 2005 Explorers 11
S alternator charging light on and not sure why. Stock 2002 - 2005 Explorers 5
L alternator/battery issues Stock 2002 - 2005 Explorers 2
S can a bad alternator cause the throttle body to go bad? Stock 2002 - 2005 Explorers 2
M Advice on Changing Alternator Stock 2002 - 2005 Explorers 20
D 2003 Explorer alternator wont charge battery Stock 2002 - 2005 Explorers 2
E Alternator and Fuses Stock 2002 - 2005 Explorers 10
C Battery or Alternator? Stock 2002 - 2005 Explorers 11
C Battery or Alternator? help Stock 2002 - 2005 Explorers 4
D 04 Explorer alternator fit an 04 Ranger?? Stock 2002 - 2005 Explorers 8
C Whining sound from alternator area... Stock 2002 - 2005 Explorers 7
T Alternator or Alternator Bearing? Stock 2002 - 2005 Explorers 4
M 4.6L & 5.4L Engines Alternator Replacement Stock 2002 - 2005 Explorers 3
M Load Testing Alternator On Vehicle Stock 2002 - 2005 Explorers 7
J My alternator is not charging the battery Stock 2002 - 2005 Explorers 1
D 03 Sport Trac Alternator??? Stock 2002 - 2005 Explorers 0
F Alternator issue? Stock 2002 - 2005 Explorers 4
K Alternator Stock 2002 - 2005 Explorers 2
S Alternator - not grounding between the steel half and the Aluminum Half. Stock 2002 - 2005 Explorers 2
F Alternator issues Stock 2002 - 2005 Explorers 7
H alternator fire Stock 2002 - 2005 Explorers 3
0 Alternator bearings Stock 2002 - 2005 Explorers 2
K White wire for alternator? Stock 2002 - 2005 Explorers 2
T Could it be the alternator? Harmonic balancer? Stock 2002 - 2005 Explorers 16
M Alternator Replacement Help Stock 2002 - 2005 Explorers 13
R Stalling after starting, just installed new alternator Stock 2002 - 2005 Explorers 10
C New Battery,New Alternator still no charge but battery guage shows half! Stock 2002 - 2005 Explorers 2
T Alternator Stock 2002 - 2005 Explorers 5
Similar threads
