jamesapost
- May 18, 2010
- charleston sc
- 1992 ford explorer 4.0 4X
i have a 92 explorer 4x4 4.0 and iv replaced the fule pump 2 times in 6 months, every so often the truck ill lose power like it all of a suden ran out of gas, and then a split second latter it will be normal again, some times it goes months without doing this some times its every few seconds! iv changed out almost everything, the throtal postion sensor, mas air flow meter, ideal air controler, tested the fule presure regulator, new fuel pump relay, coil pack, plugs wires, checked the timing, and its good. im going nuts with this. it seems like it hapnes more often when its wet outside! i dont know thoe. i have reason to belive my alternator is bad, my question is, can a bad alternator make a truck run like this, or what else could it be???? i love this truck its got over 340,000 miles on it and other than this it runs like a champ.
