It does help. What I'm concerned about is at idle with full load the battery does discharge some. Most vehicles I've owned will maintain at or more then 14 volt.
I never tested the explorer prior to changing the alternator so I don't know what the norm is for this vehicle.
When I first start the truck it runs 14v with everything on at idle. After it warms up is when it starts dropping. I would think the regulator would increase output as the battery tops off. Maybe the best thing to do is get it warmed up, turn everything on and see if it stalls.
14 V. after starting should only appear when the battery state of charge is fairly low, OR, the battery has become borderline unable to accept a full charge. Let's say a fully-charged battery starts an engine, fairly quickly, just a few seconds cranking. That process should lower a good battery's output by maybe a volt or two, this being it's voltage right after cranking the eng. stops. System voltage might then jump to 14V., this being provided by the alt., as it provides both re-charge current, and eng. running current. (current is Amps.). It should take no more than about 10 seconds or so to bring the battery back up to full voltage, at which time the measured voltage should have dropped back down to perhaps 12.8 or 13, where it should STAY pretty much, regardless of changing loads imposed by accessories.
(bold). Actually, just the opposite; system voltage SHOULD drop a little while after starting, as the charge has been returned to the batt. The discharge of the batt. imposed by starting, having dropped it's output to maybe 11V, requires a
differential of voltage to be imposed, several volts MORE than the batt. voltage, to cause current flow
backwards, that is, BACK into the batt. That difference in voltage between batt. and system (alternator) decreases as charge is returned to the batt. Once full-charge is back in the batt., system voltage remains EQUAL to batt. voltage,
thus no current leaves or enters the batt. A sudden need for more electrical energy, like switching on headlights, results in alternator instantly meeting that added current demand, while batt. sees
no change.
If alt. cannot meet the demand, for whatever reason, batt. must then make up the difference, resulting in discharge of the batt. The thing making this difficult to picture is that YOU can't measure the battery's output voltage SEPARATE from the alternator's output. The voltmeter only shows SYSTEM voltage, once the eng. is running. The only way to absolutely know if the batt. is getting current (charging), or supplying current (discharging), is to have an AMMETER in series with the battery. The old-time cars and trucks had 'em, and one could always see if the batt. was being discharged or not.
Does this help more? Glad you answered. Makes my effort feel worthwhile! imp
