AMP Gain Help | Ford Explorer - Ford Ranger Forums - Serious Explorations
AMP Gain Help
Josef86
Merrimack, NH
2003 XLT
HU is Eclipse CD5030. (claims to have 5 volt preout). Amp is JL G1700. It says there are two input mode low voltage (200mv-2v) and high (800mv-8v)
I am trying to set the gain using a multimeter like it says in the book (very hard for me to hear when it distorts at 50hz).
I have HU at 75% volume and all speakers disconnected (external amp for speakers fuse pulled) and on the sub amp (jl g1700) I have the sub disconnected. I put the 50hz cd in and put the multmeter leads into the speaker outputs.
When I use the low input voltage mode my meter shows 47 volts even with the gain all the way down. I am supposed to bring it up to 37.4 volts. So its reading high. When I switch it to high voltage input I can only read about 9 volts maxed out.
Am I doing something wrong? At this time all I am I have done is turned my gain all the way down and run the sub like that. If the book says I am only supposed to get 37.4 volts why am I getting 47. Could be a typo I guess, really wish I had an oscope.
I am not sure if its correct but I disconnected one of the RCA and the voltage dropped 10 volts. I never had this problem with the old e1200,
Beastb15
Kansas City, Missouri
'04 EB
you have all EQ settings to flat, bass boost etc set to 0? You have the multimeter set to DC low-volt?
Josef86
Merrimack, NH
2003 XLT
Bass boost off, EQ is flat.
The amp has a low volt high volt switch on it. I guess it adjusts the range it looks at for input. Multimeter is set to AC.
On monday I think I am going to go back the shop I bought the amp from and have them take a quick look at it. The owner is pretty cool and if hes in he will help me out.
