redrig, i'll answer you if you can't figure it out but i'd rather teach you something if your game.
take your fuse rating... 25 amps.
take your voltage.... 13.5 volts
take your resistance..... 4 ohms.
then go here:
http://www.ohmslaw.com/
and try and figure out what your amp is putting out.
these are the factors to take into consideration..... Your amp is a class AB amp so the efficiency is not very good. this means your power supply in your amp will consume a lot of the power the amp is drawing. The more the power supply consumes, the less your subs get.
So let's take the percentage of 40 and call it your efficiency. take 40 percent away from your fuse rating. that leaves what roughly? 15.5 amps or so? that's the amount of power being consumed by the audio section of the amp. that's the power your doing in amps.
Now ... you want to know the power your doing in watts.. so take 15.5 amps, 13.5 volts, and 4 ohms resistance and go to that website and find the equation for it. see what you come up with.
Side note: For class "D" amps the efficiency rating is much better. 68 percent efficient or better.
