2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
oil flow
For a stock engine oil from the pump is fed directly to the block oil filter adapter, thru the filter and back into the block. The photo below shows the horizontal oil channel across the front of the block to the oil pressure switch.
Oil pressure is probably greater at the filter adapter than down the flow path at the pressure switch which activates above about 5 psi. But the difference may not be significant. Oil filters have a bypass valve that allows unfiltered oil to flow to the engine when the filter becomes clogged. I wonder what the bypass pressure setting is for the Amsoil full flow filter.
