Kikinz24
- April 1, 2017
- Youngstown, ohio
- 2015 Explorer base
Okay so I have been looking into the Android radios for the Explorer and come to find out these radios do not support the factory remote start options in retaining the heat and AC controls I'm curious if anyone has ever figured this out yet what I'm really trying to figure out is will the heat and AC functions not work with the remote start because there is no power to the aftermarket radio bezel. If that is the case could you not use a 12-volt power that comes on when you do use remote start for example the the gauge cluster.
Also
Does anyone know if the heater control module and blower motor get power when you push the remote start but just do not turn on because there is no signal or if there is actually no power whatsoever to them.
Also
