TennTechMan
- April 12, 2007
- Maryville, TN
- '94 Sport
Another 4.0L OHV Build Thread (with 95TM heads) Now with a Video!!!
A couple months ago I picked up a '94 Sport 2-wheel drive for a very reasonable price with some motor problems (previous owner is a ExplorerForum member). My original intention was to swap a V8 drivetrain from a mid-90's model Mustang GT. After considering the total cost vs. benefit of the V8 along with reading through Craeger's thread, I had decided to build up the 4.0L unless the whole motor was trash. I've now got the motor pulled and tore down. The bottom end looks fantastic. One head has an exhaust valve with some damage, but it's destruction has done nothing to the rest of the engine.
I've thoroughly read about 75% of Creager's OHV build thread and skim read the whole thing twice. I had intentions of doing a very similar build until I had the heads pressure checked for cracks. Both of which were cracked at the bridge between the intake and exhaust valve on the middle cylinder. Since I'm buying new heads anyways, I figure I'll buy the 95TM ones to get to the ~10:1 compression ratio. I also want to use the 422 CompCams cam. I'm a little worried about valve clearance. Does anyone have this exact setup to confirm everything clears? Is there any reason why I should choose to use 94 model heads and SOHC pistons over 95TM heads and 94 OHV pistons? Does anyone know what pushrod length I would need with the 95TM heads? Where's a good place to get the upgraded valve springs that I will need with the 422 cam?
Here's a rough parts list so far:
-Rebuilt 94 OHV bottom end (stock bore, hot-bathed and honed, new oil pump, new bearings, new rings, possibly new pistons)
-New (not reman'ed) 95TM heads
-422 cam and custom length pushrods
-Stock rockers and lifters
-Upgraded valve springs (recommendations?)
-Headers and Y-pipe (JBA?)
-New timing set
-New water pump, etc.
Any input is greatly appreciated (both possitive and negative).
Thanks,
Aaron
-New timing set
Thanks,
Aaron
