Another A4LD question | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
UnXPeCTeD
Jonquiere
Hi Guys,
New member here, just found you this past week-end and I learned a lot from all you people here. Nice to see nice people around here to share with others all the problem and advice from everybody.
I'm the proud owner of a 1994 Explorer LT V6 4.0L. Last week I blew up my transmission and we swap it with an A4LD from a 1990 Bronco II with a 2.9L on it. This was my father old Bronco and from what we were told the transmission was the same except for the bracket on it. Anyhow, after the swap it seems to me that the shifting of it is quite different on the two first gear. My question is: Does it need another modulator or anything else to be recalibrate to make it work or does just a swap from one to another is OK? The only thing we swapped from the two transmissions were the bracket for the shifting rod, those 2 were different. Do I need another modulator calibrated for a 4.0L engine? Any help on this issue would be greatly apreciated. I don't want to messed this new/old tranny we've put a couple hour to install for nothing.
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
Glacier991
EF Tranny Guru
Moderator Emeritus
Sacramento, CA 95827
1992 XLT
there were some valve body differences between the 2.9 L and the 4.0 L, a couple of parts differences and I am not sure about the modulator but I think it was the same. Get a valve body from a 4.0L A4LD and swap it in.
UnXPeCTeD
Jonquiere
When you say a couple difference, what else would be different beside the valve body? Any Idea?
Brian_B
Mountain Home, AR
2000 mounty / 56 f-100
There are some internal differences (strength), but I never rebuild one behind a 4.0, so I don't specifiaclly know what.
UnXPeCTeD
Jonquiere
I was told this morning that the torque is different from one to another, reason why the RPM is higher from the 4.0 to the 2.9, I was told that it will work like it is but a little more expensive on the fuel. I can't swith the valve body, my old tranny valve body was done, the only shifting I had were OD and P. I will use it this way and when this one will be done I will by a newer Explorer. Thanks for the advice.
