bvenvert
- September 14, 2005
- Springfield, Illinois
- 91 Ranger XLT
Well, I have been all over the forum reading about brake problems and the corresponding repairs and I feel like I might have too much information, if there is such a thing.
Anyway, I have a 91 Ranger 4x4 and I now have a brake issue ,which results in the brake pedal going all the way to floor with little or no braking power. I have tried to bleed the brakes which goes smoothly on the rears and after about three or four tries, I can get the air out of the lines. Then I moved to the front, right side and have spent literally ten to fifteen minutes trying to get the air out of the lines, with no luck. It seems that every time I pump up the brakes and release the pressure through the bleeder valve at the caliper, I have bubbles appear inside the glass jar. I had a friend of mine over to monitor the brake fluid in the reservoir and he says he can see bubble coming up in the reservoir while I am releasing the bleeder valve at the right front caliper. Would this indicate that I have a bad master cylinder? I was under the impression that you should never see air bubbles in the reservior, especially when you release the pressure at the bleeder valve. I replaced the booster and the master brake cylinder three years ago and the truck doesn't get driven that much, but I wouldn't think it would need to be done again already.
I guess my second question is could the ABS or HCU (Hydralic Control Unit) be causing the problem? I am not sure the truck even has an HCU, but I have read on the forum that once you get air in the HCU, you need a special tool in order to properly bleed the air out of the system. Along with this if I had air in the HCU would the vehicle be throwing up an ABS light on the dash? I do not have any lights at this time.
Thanks in advance for all your help.
