Paul Yeager
- July 17, 2016
- Waynesville
- 2002 Explorer XLS 4.0
A week ago, my 2002 4.0 SOHC Explorer started running quite raggedy. The OBD code indicated a misfire on cylinder 2.
I stopped by a local auto parts store to pick up an ignition tester, which indicated that I had spark to that cylinder. I really wish that had at this point done a compression test. Instead, falling prey to wishful thinking, I concluded that the injector must have failed.
So I replaced the #2 injector, and while I had the intake manifold off, replaced the driver side valve cover gasket, which was leaking. Put it all back together, and after several hours of work, no improvement.
Now, I did the compression test that I wish I had done first. Zero. Zip.Zilch. Nada. I concluded I had a valve problem. Off came the intake manifold again.
When I went to remove the passenger side valve cover, I discovered that the EGR tube was in the way. Oh joy! So easy to get to. Not! A couple of open end wrenches just didn't allow me to get enough torque on the flare nut attaching the EGR tube to the fitting on the exhaust manifold.
A crowsfoot wrench seemed the obvious solution, but they are as rare as hen's teeth out here in the mountains. I ordered one, and while waiting for it to arrive I periodically sprayed the fittreplacingBlaster.
The crowsfoot arrived, and the compression nut on the EGR tube yielded. I was finally able to get the EGR tube out of the way and remove the valve cover.
Once I had access, I discovered that I could depress the #2 intake valve with my finger, and there was a crazy amount of play in the rocker for that valve.
So, there is my tale of woe. Does anyone have any advice on replacing a valve spring in this engine, preferably without removing the head?
Thanks!
Thanks!
