koda2000
- September 2, 2011
- x
At least 5 years ago our '00 Mountaineer 5.0L developed a chirping noise, which drove me crazy. I finally figured out the noise was coming from the area of the cam position sensor (a common 5.0L issue). Someone suggested removing the sensor and to try putting a few drops of ATF on the cam synchronizer's shaft. I did and the noise was instantly gone. In 5 + years/60,000 miles the noise has never returned. Last year I put a few more drops on it just as a preventive maintenance item.
About 2 weeks ago my '01 Explorer 5.0L started making the same chirping noise when cold. I removed the CPS and again applied some ATF to its synchronizer shaft and so far the noise hasn't returned. If it does I suppose I'll need to replace the cam position synchronizer, but if it stays quiet - good enough.
Tips:
I use a 1/4" ratchet with a 6"-7" extension, a universal joint and a tiny SAE socket to access the two tiny CPS screws/bolts and sneak it under the coil packs to remove the CPS. Then I put maybe 4 drops of ATF around the synchronizer's shaft. I use a dental flushing hypodermic device I've had forever to deliver the ATF where it's needed. Don't put too much ATF in there as it will just leak out a hole in the housing.
If you do end up replacing the synchronizer, spent the money for a new Motorcraft replacement. as aftermarket rebuilt units tend to break.
Tips:
