duke16
- March 10, 2001
- Raleigh, NC
- 1997 5.0L AWD XLT
I have developed a coolant leak on my rebuilt engine. It seems to be intermittent. When it's leaking, it's pretty bad and I get a nice pool of coolant under the truck, center to drivers side. Yet this morning I drove to work and it was fine (so possibly only leaking when the engine gets really hot, I only drive 7 miles to work). It drips down on the driver side above the sway bar. The highest I can see it is about where the hose from the water pump to the oil filter adapter is, there's coolant on the bottom of that, but none on the top. When I hook a pressure tester up I can hear the leak near the center, just a little on the passengers side. So I guess the fan may be pushing all the coolant to the driver's side as it drips down. It's not spraying anywhere, so I feel like it's pooling somewhere on the engine and then overflowing. The water pump is new, so I doubt the seals are bad... but I wouldn't want to rule that out. Only other thing I can think is the lower intake gasket is bad. Any other ideas? All the hoses appear fine.
