H2opro
- October 16, 2014
- Mn
- 06F-350,98mountaineer
Hey all,
I know this topic has been covered before. I have a 98 mountaineer 5.0. my t case went bad. I think it was the seal in the VC. Had rear wheel drive and the front would only spin if you really got on it. So I swapped the t case out with a lower mile one. Now I have a pop/ clunk sound in the front drive line. Front diff has no metal in the fluid. Nether does the new case. I took the original front drive shaft out and the CV joint on the t case side fell apart. So I swapped the drive shaft out with a used one. Still does it. I don't now the history on it. Came out of a truck I used to V8 swap my ranger. Truck had 200k on it. And the shaft sat outside for a few months .The will pop if you load the truck with the brakes. Or just take off. My guess is it's the front used drive shaft. When going do the road I hear a buzz/ clicking sound under my feet. Could the t case chain be bad? If I have to buy a t case that's fine I would just order a reman. A reman driveshaft is 300 bucks if imthe wrong forum feel free to move it. Once again I know no history on the used drive shaft I put in the truck. It work fine when I drove the donor. But then is sat in the back of a pick up truck for 6 month.
Thank you for the help in advance. Sorry about the grammar.
