smns77
- August 31, 2012
- pennsylvania
- 97 ford escort
if you take the engine and trans ecu from a ranger or explorer why not the headlight harness to arnt the headlights the samethat it would it just plug up together p.s. one if your bronco had electronic 4x4 but the huds were replanced with manual ones do you still need the selector switches on the dash or could you remove them and put auxillary likghting switches in that position and is the 4wd control module needed any longer at that point
