Willard
- March 16, 2007
- Bloomington, Indiana
- 04 Ranger Edge
Ok, I have been having EGR problems for god knows how long now. Everything runs fine, I still have a CEL though. I have always had EGR codes, 332 and 335 come to mind. 332 means insufficient EGR flow and 335 is EGR circuit voltage out of range. Awhile ago, while trying to fix it, I ended up replacing everything. EGR valve, solenoid, and DPFE sensor. Since it's warmer out, and gas is expensive, I've started trying everything to find the issue again.
I tested the EGR valve, and it works flawlessly. I even applied vacuum with the engine idling, and the engine bogged down as it should.
I tested the solenoid, it give proper resistance, and the motor didn't run right after I hooked the hoses up backwards on accident, so it seems to work fine.
The only thing I found is that while running and hot, the DPFE still gives around ~.8 volts, which is what it is supposed to be when completely closed. The reference voltage is fine right around ~5.0 volts.
So I guess this means the DPFE is bad, even though its less than 6 months old? On the other hand, it never made a difference when it was new, so maybe I got a bad one from the start. I'm asking because I know things like the ECT can cause EGR problems as well. I tested the ECT at some point, and it's resistance seemed to be fine.
So, I guess, is it worth a shot throwing another DPFE at it? I'm tired of just throwing money at my problems, I want it to be the right part this time. Should I test the ECT again? I'm thinking about another DPFE, I want to be sure though. :scratch:
