Another Explorer with transmissions issues - I think!
BoweP
Fresno, CA
1994 Explorer XLT
Hey all, I have a '94 4X4 with the A4 in it. It has started to give me some sort of transmission issue, and I'm prepping for a new one. I was at a stop light yesterday (following a friend to the mechanic, ironically) and as I started to let it creep forward in drive, it felt like I hit the brakes hard for a second. It was fine after that, and I talked to the tranny guy at the shop we headed to about it. He said check your fluid, make sure it's not dark or burnt smelling. He said when you put it in park or neutral, it will still want to move, and that's a sign it is heading out. Well, my fluid was fine. I'm real particular about all of my fluids. However, when I got home, I decided to put it in neutral. It started to creep as if it were in drive. Then I shifted into park, and it kept going about 6-12 inches before grabbing and coming to a stop.
What do you all think? Are there any good tranny removal guides? I checked the page for them and didn't find a real clear cut removal thread. My Chilton repair manual leaves a bit to be desires.
trashtruck
capital district, ny
1992 explorer xlt 4x4
pulling a trans isn't that difficult, especially if you've done it before. it is time consuming and labor intensive if you haven't. just make sure you have the necessary tools before you begin. use common sense and you should do fine. rolling in neutral i wouldn't worry so much, rolling in park is something else entirely. if you can't find info on this forum try the ranger forums. they usually have some pretty good info.
BoweP
Fresno, CA
1994 Explorer XLT
Thank you for the reply and your input! I dropped a tranny on an old '72 mustang, but never this explorer, and never something with a t-case. The rolling forward in park is what sold it for me, really. Although it doesn't do it every time, which is odd to me. I'm thinking that going with a low mileage, used transmission would not be wise. Especially given that the Explorer only has 57K miles on it. It can't get much more low mileage than that, and it still is failing.
trashtruck
I know the a4ld wasn't fords proudest moment but i understand re manufactured is superior to rebuilt.
2stroke
Location
55302
Annandale, MN
1993 Ford Explorer Sport
It's just a pawl that jams in a gear for "Park". I'd take a look at your shift linkage first.
natenkiki2004
Blue Bomb!
Location
North Idaho
1991 & 1994 Explorers
x2 on this.
Linkage could be out of adjustment. If the parking pawl was broken and the linkage was out of adjustment, you can get the forward clutch engaging. My 1991 does it from time to time but the trans is solid aside from that. I've simply learned to park in neutral with the e-brake applied if I'm going to get out with the engine running.
BoweP
Fresno, CA
1994 Explorer XLT
I had thought about the shift linkage potentially being an issue, given that the transmission feels otherwise great. I wasn't sure how to address it, though. What do you check for on the linkage? Thank you!
natenkiki2004
Blue Bomb!
Location
North Idaho
Here's what the factory service manual says:
ghosttrain2 1994 Explorer Limited- yes I bought another one... Stock 1991 - 1994 Explorers 18
D 93 Explorer surge at 45...another MAF?? Stock 1991 - 1994 Explorers 0
Explorin'VA Bought Another Explorer Stock 1991 - 1994 Explorers 2
F Another Explorer Experience! (my story #2) Stock 1991 - 1994 Explorers 2
T Odd popping sound off front end, plus another issue Stock 1991 - 1994 Explorers 1
C Another Code 543 question... <SOLVED> Stock 1991 - 1994 Explorers 1
E Another rear wiper thread.. Stock 1991 - 1994 Explorers 12
Swinson1974 Rebuilding another Gen1 Head Gasket... Stock 1991 - 1994 Explorers 2
D Another question about the first gen moonroof Stock 1991 - 1994 Explorers 11
M Yet another problem; front end suspension, shocks, or ball joints Stock 1991 - 1994 Explorers 10
C another stumbling idle thread Stock 1991 - 1994 Explorers 9
M Another head gasket thread Stock 1991 - 1994 Explorers 138
T Another "Where's my coolant going?" thread... Stock 1991 - 1994 Explorers 2
C from one thing to another: time to pass CA emissions Stock 1991 - 1994 Explorers 6
L Yet another 4x4 problem. Stock 1991 - 1994 Explorers 4
C Another Brake Question: 1994 w/ABS Stock 1991 - 1994 Explorers 8
L Another Door thread. Stock 1991 - 1994 Explorers 2
W Another Rough Idle Problem Stock 1991 - 1994 Explorers 5
9 Another auto hub question. Stock 1991 - 1994 Explorers 13
R Another code 214 issue.... Stock 1991 - 1994 Explorers 2
K Is there another way to fill the rear diff? Stock 1991 - 1994 Explorers 16
L Another 94 Auto Hub issue Stock 1991 - 1994 Explorers 0
S Another Mazda 5spd Trans issue... Stock 1991 - 1994 Explorers 7
E (another) auto hub question..long...sorry.. Stock 1991 - 1994 Explorers 7
O Another Newbie ? Front Door Locks & Guages Stock 1991 - 1994 Explorers 8
W Air one day - gone the next or another a/c question Stock 1991 - 1994 Explorers 1
J Buying another X maybe..... Stock 1991 - 1994 Explorers 15
E Yet another Wheel Bearing Post....DRONE DRIVING ME DAFFY!! Stock 1991 - 1994 Explorers 10
C Another day another problem. ABS light Stock 1991 - 1994 Explorers 17
F Another fuel line issue Stock 1991 - 1994 Explorers 2
V just another question Stock 1991 - 1994 Explorers 4
E Swap transmissions or buy another one? Stock 1991 - 1994 Explorers 3
D Got another Navajo Stock 1991 - 1994 Explorers 6
M I AM BACK!! With another 94XLT Stock 1991 - 1994 Explorers 6
A Yet another A4LD bitching thread Stock 1991 - 1994 Explorers 7
B If it's not one thing....it's another! Stock 1991 - 1994 Explorers 5
B Seriously ANOTHER brake master cylinder??? Stock 1991 - 1994 Explorers 19
W Another manual hub conversion question Stock 1991 - 1994 Explorers 3
SavaX Another window Q Stock 1991 - 1994 Explorers 3
S Another Power window problem Stock 1991 - 1994 Explorers 6
D truck and wallet dont like one another Stock 1991 - 1994 Explorers 4
I Yet another Lift question Stock 1991 - 1994 Explorers 4
Willard Another voltage drop problem - Need an electical guru Stock 1991 - 1994 Explorers 11
B Might be picking up another 92 Eddie Stock 1991 - 1994 Explorers 13
K 92 4x4 a4ld swap with another 92 4x4 a4ld Stock 1991 - 1994 Explorers 2
M Another foot in the grave for my A4LD.... Stock 1991 - 1994 Explorers 7
CmdrPopNFresh another summertime ac question Stock 1991 - 1994 Explorers 6
K Another Auto Hub Question. Help Needed! Stock 1991 - 1994 Explorers 3
B Another Brake Issue Thread Stock 1991 - 1994 Explorers 16
W Yet another 4 x 4 question / Auto Hubs Stock 1991 - 1994 Explorers 36
Similar threads
