SevyDuce
- July 27, 2008
- Walnut Creek, CA
- 1993 Sport
1993 Explorer 2Door, manual, power windows/doors:
The passenger side window just stopped working one day. No motor spinning indicating bushing wear (like my driver side window). The switches seem to work because I get a slight dip in the voltage meter on the dash when I press the button on the driver's and passenger's side switches. Also checked fuses under the hood - I believe those are the only ones that are for the windows.
I have done some research here and I'm not sure if it's a bad motor or bad regulator. Motor removal/install guides I've seen, but I haven't seen anything on the regulator.
Could it be anything else?
Thanks in advance.
Thanks in advance.
