Another question for bypass/blowoff valves
Makahveli
Denver, CO
'92 Sport and AMG 300CE
For forced induction air I've done research and maybe mistakin but it seems that if you drive a 5-speed manual that a bypass or blowoff valve is reccomended, if this is so for us guys just running 6psi what spring rate should we be looking forward to getting? Like when the throttle is suddently close from WOT Does the boost almost double since it has nowhere to go? I'm not looking forward to upgrading pulleys anytime soon, but am I to only get a valve when going over 12 psi? I don't have access to a boost valve yet, as I don't think its needed or am I wrong?
T another freakin exhaust question.... Need for Speed! 3
Dono Another OHV M90 build Need for Speed! 1585
5 Here comes another turbo Mounty! Need for Speed! 9
Makahveli Another blown 4.0 Need for Speed! 7
Fredness NA4LSOHCBUT [Not ANOTHER 4.0L SOHC Build Up Thread!] Need for Speed! 152
Alec Another trip to the drag strip! Need for Speed! 10
C Cam question Need for Speed! 0
J header question Need for Speed! 8
D 96 5.0 cam question Need for Speed! 9
Scott B. AOD / 4R70W Gear Ratio Question Need for Speed! 5
Scott B. 302 Stroker question Need for Speed! 3
Scott B. 5.0 L Intake Question Need for Speed! 1
Scott B. V8 Motor Mount Question Need for Speed! 7
D 97 5.0 X question Need for Speed! 4
A Quick question about air intake Need for Speed! 8
O 4R70W 3000 stall and towing question Need for Speed! 28
I 2nd gen 5.0 exhaust port to steering shaft question Need for Speed! 2
htrdlncn Question about X-Charger Need for Speed! 3
Makahveli Return to stock injectors? and a compression question.... Need for Speed! 13
J Question Megasquirt & Our Automatic Transmissions Need for Speed! 16
S Twin Turbo Question Need for Speed! 12
L Wheel size and performance question. Need for Speed! 2
N Quick header question Need for Speed! 1
section525 Speed and power question Need for Speed! 20
V Question on spark plugs for nitrous system Need for Speed! 8
R fuel injector upgrade question Need for Speed! 4
S SOHC 4.0 Cam Question Need for Speed! 12
L question for the ZEX users Need for Speed! 6
E BBK SC QUESTION Need for Speed! 7
E Hey question for alec Need for Speed! 14
james t help; troll & blk mk8 charger question Need for Speed! 9
