- February 9, 1999
- Vail, Arizona
- 1992 XLT 4x4
Well, I finally did it.. I sort of went SOA (not finished). I tried not to go SOA as the SUA rode great BUT I got sick of hitting the springs, spring plate, shocks etc that hang under the axle.
So, last Friday I grabbed the 8.8 SOA conversion kit I got from RuffStuff a while ago and decided it was time...
When I started (I didn't take a pic) the Front fender lip was 40.5" and the rear fender lip was 37". On top of that, there was only 1/2 tank of fuel in the truck and it was sagging that bad.
A quick shot of the SOA kit installed. I drilled out 2 of the holes on the top plate. The center one for now and the front one in case I want to move the axle back some. I also had to drill out the front/center hole on the spring perch. I'm using m10 bolts (allen head style) as the spring bolts.
almost done with soa by maniak_az, on Flickr
At the end of day 1 I had the axle under the truck (u-bolts not tight yet). I still had to put on shock mounts etc.. The truck is about the height I want (I love my tall jack stands) and the rear suspension is sitting on jack stands in the pic.
I welded on the shock mounts on Sunday. I welded them onto the sway bar brackets. I put them near the bottom (I don't have a pic yet).. They do hang a little lower than the axle but as I see it, if I didn't do that I would lose up travel and I like my up travel as its more stable than down travel plus it has more weight on the tire then.
Here it is as it is now (took the pic last night). I have it on its own weight. I still have on the War-153 shackles and I have a set of stock springs with the overload removed. The Rear Rancho shocks are being replaced (on the way from amazon). Both shocks are now stuck on 10 (stiffest setting) and that in combination with the stock springs makes the rear very stiff compared to the front.
SOA - on its own weight by maniak_az, on Flickr
The front fender measures 40.5" and the rear measures 41". That 1/2" higher in the rear makes it look worse than it is. I'm going to try a set of Warrior 115 shackles (5.75" eye to eye) to drop it 1.5" and put on my softer springs. If that doesn't work I'll see what I can make out of my 2 sets of springs but I'm going to wait until I get the new shocks on.
I'll grab some more pics as I work on it more..
~Mark
~Mark
