^i couldn't help you cause i'm still trying to remove the crank pulley. but i need to find out where i can get the right size bolt for the puller. I tried home depot, lowes, autozone, and oreilly.
ok i found some bolts that will work and have everything on but i think i might be doing something wrong. everytime i go to turn the middle part of the pulley the whole pulley turns which makes the motor turn over. what am i doing wrong?
How is that piece on the right of that timing chain removed?
I finally got those Guides in. It took a little more than just wiggling But I got the motor together yesterday. I put it back in today & it sounds great. Hopefully I won't have to do that again for awhile. Thanks for the help.
so if i were to repair all the front timing chain components I would have to remove the valve cover or the whole cylinder head?
