shane10
- February 9, 2016
- MW
- 2002 Explorer XLS
4WD
Hi all, I know this topic has been beat to death, but cannot find a direct answer to the question at hand.
Rear cassette guide has broken, who knows how long ago, planning on pulling the engine and changing all timing components asap. Thanks to 2000streetrod's amazing threads regarding this topic, I priced out OEM parts at about $600, seems a bit steep for an 02 truck, so I think I have decided to go with either Cloyes 90398SB or Melling 3398S.
Here is where my confusion comes in.
On rock auto the Melling set has a statement "Engines With Balance Shaft; Due To Numerous Changes To This Engine The Front; Jackshaft, Crankshaft and Balance Shaft Sprockets Must Be; Updated To The Latest OE Design. There Is A 2mm Shift In Centerline; Timing System Failure Will Result If Original Sprockets Are Re-used"... According to the picture/description it seems like this kit only comes with chains/guides/and tensioners, and NOT sprockets, if going this route, would it be wise to buy new sprockets from ford?
On Cloyes set there is a statement "Cloyes Timing Kits MAY include camshaft sprockets, crankshaft sprockets, timing chains, tensioners, and guides"... MAY? This does not sound very promising, and again there is description part by part.
If anyone out there has any experience with either of these kits some clarity on what is/is not needed outside of the kit itself would be much appreciated.
As long as I have the engine pulled I plan on doing...
Exhaust manifold gasket
Head gasket
Water pump (?)
and of course all gaskets/seals will be replaced, anything I am missing?
Just wanting to make sure I order the correct parts (within and outside the kit) and receive everything needed for the job before I dive into it.
Thanks in advance, all the help I have received here has been truly invaluable
Head gasket
Water pump (?)
