Mr. Alligator
- November 30, 2014
- Tampa, Florida
- 1997 XLT Explorer
I have a 1997 Explorer 4.0 SOHC with automatic transmission. Recently, “4wd 4lo” dash lights began to flash six times every few minutes. Also, the front end often has slight to moderate grinding/binding around slow turns. There are lot of posts about this issue, and some report the exact same symptoms. But almost all of the threads end without resolution. Thank you for your consideration….
Four wheel high and four wheel low respond to the dash switch properly for a few miles after start up, then the dash lights flash and the four wheel drive no longer responds. The grinding/binding through turns occurs before and after the flashing and regardless of dash switch selection.
The transfer case can be shifted to four wheel drive in the first few miles, before the dash lights begin flashing. After the dash lights flash, the truck will stay in 4h,but no longer responds to any switch commands.
I have checked fuses suggested on this Forum, then had the transfer case rebuilt. I assumed the transmission company that rebuilt the transfer case changed the speed sensors (but I have not asked, yet). The transmission company believed this was a mechanical, not an electrical issue.
Then I replaced the drivers side hub assembly, as the binding seemed to be primarily from the drivers side. This did not result in any improvement.
I also removed the transfer case shift motor. It appeared to have parked leaving the directional shaft about 80% of the way toward 4h. Using pliers, I manually rotated the shaft the rest of the way to 4h, and drove with the shift motor removed from the transfer case. Still, no improvement.
Oddly, after the dash lights begin flashing, the front wheels do not engage (unless 4h was already selected), BUT the grinding/binding continues unchanged.
Dang. Any ideas?
Dang. Any ideas?
