The #1 Ford Explorer enthusiast resource for 25 years! We cover the Explorer, ST, Lincoln Aviator, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Aerostar. On and offroad projects.
Register Today It's free! This box and some ads will disappear once registered!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose
fix problems yourself and learn which modifications work without having to experiment on your own.
Elite Explorer members see no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery,
create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
Creating some at the moment... I have two send out tomorrow so if you want, I can send two more out for you. Just paypal $40 to BBX@ec.rr.com and give me your email and stuff... Same goes for anyone else that wants them.
They are actually pretty good, the only problem i have seen is that the bracket moves a tiny bit, rocking the plastic that it is connect to. Im a little scared if i hit something with the antenna that it will brake off the bracket where it is connected.
SWR is the Signal to Wave Ratio. It is the power that is reflected back to the CB from your antenna. Anything over 2:1 and your going to cook the finals fast.
Is that when you take a watt meter and measure forward (output) and reflected power by switching the direction of the plug in the meter? This is what we used to do on police radios and no more than 10% was the goal.
I had the same problem but what I did was attached a small piece of felt to the side that touches the gate a little then bent the bracket just enough so that the gate WILL hit it when it closes. It seems to put enough pressure on it to keep it from moving... as for breakage, I assure you that these will not break. I have one on each side with 3 ft. fiberglass k40's... people slow down for my truck daily, thinking that I am with the PD around here. Thank God I have a bunch of cop/sheriff buddies.
Take care and if any of you need any more, I just had some more come in. Enjoy!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
