antenna
leebo
Moderator
Staff member
Moderator
Mingo Junction, OH
1994 Explorer Sport
I've just finished installing my cobra cb today. I turned it on and as I expected the antenna I had bought was horid. I just bought a cheap one from Radio Shack to use till I can find another one I like. I was going through the site when i saw that there were several people here with some mounted on their bumper. I kinda like that idea. If anybody out there has done this please tell me how well it works, how much for the antenna, does it block the tailgate????? Any help will be great 10-4, and out.
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
Char
Admin's Wife, Explorer Babe
Staff member
Wittmann
1993 Explorer XLT
Callsign
KB7TKQ
leebo,
It may not just be that your antenna is crap. Explorers at least early years like yours and ours have horrible fuel pump noise. If I remember correctly the noise level was like S8 on the meter. There was a TSB for it if I'm not mistaken. Don't remember cost or anything else. Rick is not home right now or I would ask him. Hope this helps some.
leebo
Moderator
Staff member
Moderator
Mingo Junction, OH
1994 Explorer Sport
I'm not sure how close this is but I was able to adjust my antenna and received a check of about 4 miles. This was in the city on channel 19. I also had better range on another channel in which I got about 7 miles range. I guess I'll stick with this antenna and see if it tides me over. Thanks a ton Char. O ya, I will see if changing the filter will help too.
ExplorGM
AZ
1995 Explorer Expedition
Antennas again?
Any recommendations on which are the best antennas? I looked at the Firestik site. I would prefer a permanent mount as my magnetic antenna easily taken off by tree branches and such. Should I go with a long antenna on the roof/bumper, or with one of the cell phone look a like antennas on the roof?
Thanks!
Rick
leebo
Moderator
Staff member
Moderator
Mingo Junction, OH
1994 Explorer Sport
I myself desided to redo my antenna and also changed to a firestik. You can tell a change when the truck is off but when it's on it's about the same. I would go ahead and use it again over the cheap antenna I had though.
I went ahead and drilled two holes into my roof rack and bought a sideways mirror mount. I put the antenna on top and off I went. The cable just goes in through the door and down the door jam. You really can't see much cable at all, and inside you can't see any. I do need to buy an external ground though. They're not too expensive but I can tell I need one if I'm going to use the roof rack.
I'll let you know how this change works
FC2ED
Philly, PA but transplanted too Bryans Road, MD
1994 Mazda Navajo
Leebo,
You need to tune the antenna. Otherwise you risk blowing the transmitter. Go to the local Radio Shak and pick up an SWR meter for about 12 bucks. You will temporarily install this in-line with you cb and antenna. You can go to channel 1 and then channel 40 and tune the antenna as close to 1 as you can or go to the most frequently used channel such as 19 and tune that channel in. What you are trying to do is remove as much of the standing waves as ytou can. I'm not sure if your antenna has a tuning sleeve or not but this how you adjust the antenna to match your unit.
As far as the ground, you should ground the antenna as this will make your truck the ground plane. As an example, I'm using a magnetic mount and have the antenna mounted to the rear of the roof. This allows me to receive more transmissions from the front then the rear as I'm driving down the highway. As I travel I'm more worried about where the police and traffic are ahead then behind me. Hope this helps a little.
Ray Lobato
Moderator
Moderator Emeritus
2006 Honda Accord
Hey Rick Those cell phone looking antenna's are garbage. Don't waste your money. Firesticks are very good antennas. In fact it's better than my Wilson 1000 and alot cheaper too. The only antenna that is better would be a 109" whip antenna. Hope this helps.
philbon
hey guys i agree that the 102'steel whip is a good anteana
especaily if you do alot of off roading mount it to the rear bumper. im currently running a wilson 5000 mounted thru the cab roof on my silverado p/up works really great
just wanted to add my 2 cents worth ..........phil
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL Pumpkin Edition
Callsign
AB7FH
Another 2 cents. 102" whips are the most directional of mobile antennaes. What this means is if you mount the antenna on the right rear corner of your truck the best signal will be sent and recieved towards the front left corner of your truck. The worst area for trasmit recieve would be in the "null" behind the right rear corner. This effect is evident with any antenna mounted on the corner of a vehicle, but it is most pronounced with the 102" whip.
Some clubs won't allow you to run 102" whips on their trail runs. The reason being is that they can easily injure a spotter.
My personal favorite is a Wilson 1000 on a permanant mount in the center of the roof. Unfortunately I don't have one anymore...I broke it off :D
ExplorGM
AZ
FC2ED- On the highway, police are my concern too. Are there any specific channels that are used for this purpose?
Ray- Thanks! I almost went for the Cell looking antennas because of the ability to get into the garage.
Leebo- How's the rack mounting working out? I'd like to go that route, as the bumper mounting was not recommended on another post.
Rick- What makes the Wilson 1000 better? Ray seems to be happy with the Firestik. What is your recommendation for a ham radio for the truck? Now that I am near both you and Gerry Higgins, I am thinking about taking the code test.
Philbon-Is the Wilson 5000 better than the 1000?
Thanks guys!
Rick
leebo
Moderator
Staff member
Moderator
Mingo Junction, OH
1994 Explorer Sport
The roof rack is working out great. The only thing I'm going to redo is the ground. I didn't think of it when I installed it but the roof rack is mounted on a thin piece of plastic to protect the roof.....thus making in ungrounded from the frame. You can buy a ground kit for about $10 or so just about anywhere. I'm going to do that this weekend I think. Shouldn't take more that 15min.
FC2ED
1994 Mazda Navajo
Leebo,
I just listen to 19. Seems all the truck drivers use this as a standard channel. Be fore warned that unless you can speak their native tongue, you will not get to many responses from them.
philbon
RICK,well first off with a wilson 5000 you can run more power then with a 1000.and compairing a 5000 to a 1000 which i have had both on the same vehicle (at different times of course)i like the ears better with the 5000
but thats only my preferance. years ago i had a 66 charger that i ran a 102"steel whip on, mounted dead center of the rear bumper and talked all over the world with only 200 watts..........i currently run a 102" steel whip mounted on a custom bracket dead center of the rear of my caravan with a quick disconnect so i can remove it to open the rear hatch
door. i also have the bracket grounded to the frame...phil
Char
Staff member
Wittmann
1993 Explorer XLT
Callsign
KB7TKQ
Rick (ExplorGM),
I know where classes are being held for the Technician class and the Morse code. ;)
ExplorGM
AZ
Char-Great!
Char
I'll be over to visit with you and Rick as soon as we are settled. We move the 11th. I've been making the trip to Palm Springs every Sun/Mon to get the house ready. It will be nice to be settled!
Rick
ExplorGM
AZ
Thanks Phil!
I'm going to need some type of quick disconnect to get in the garage without damage. Most of the traffic was happening on channel 6 on Route 10 from CA to AZ today. There does not seem to be any pattern to which channel is used the most on that route?
Rick
philbon
rick
rick any advice or help that i can give you please email me
off of this list and ill be more than happy to advice you further............phil
M Low Profile Antenna for Short Distance Ham Radio - CB - Trail Communications 5
B cb radio/antenna help Ham Radio - CB - Trail Communications 3
1 Antenna help! Ham Radio - CB - Trail Communications 2
T CB Radio and antenna install on a 3rd Generation Explorer Ham Radio - CB - Trail Communications 12
1 Antenna question? Ham Radio - CB - Trail Communications 20
Dan Whitaker Permanent antenna mounts Ham Radio - CB - Trail Communications 1
D Antenna Problem Ham Radio - CB - Trail Communications 27
T Automatic Lowering Antenna - HOW?! Ham Radio - CB - Trail Communications 9
C New to Radios, Need Antenna and CB Ham Radio - CB - Trail Communications 10
LONO100 i can hear my buddy, but he cant hear me. which antenna needs adjustment? Ham Radio - CB - Trail Communications 12
A Roof Mounted Antenna? Ham Radio - CB - Trail Communications 12
R Pictures of my antenna mount as requested (not pretty) Ham Radio - CB - Trail Communications 4
M antenna spacing (tx vs rx) Ham Radio - CB - Trail Communications 5
N How to put a 3x5 flag on a cb antenna? Ham Radio - CB - Trail Communications 2
T brake light antenna mount Ham Radio - CB - Trail Communications 19
N What do you guys think about duel antenna's? Ham Radio - CB - Trail Communications 8
G Mirror Antenna Ham Radio - CB - Trail Communications 2
Elessar65 CB antenna in stock radio antenna location Ham Radio - CB - Trail Communications 3
joker1457 CB Antenna Question Ham Radio - CB - Trail Communications 3
I Tail light antenna mount install Ham Radio - CB - Trail Communications 21
I Antenna stud mount with ring connector? How to connect to cable? Ham Radio - CB - Trail Communications 5
I Roof mount CB antenna? Ham Radio - CB - Trail Communications 12
N PLEASE HELP!!! High swr on my roof rack mounted antenna Ham Radio - CB - Trail Communications 12
BlackHawk09er Antenna mount Ham Radio - CB - Trail Communications 6
Turdle Dual antenna install ??? Ham Radio - CB - Trail Communications 26
P Wire CB to stock FM Antenna? Ham Radio - CB - Trail Communications 2
L HOW TO: ball mount for CB antenna installation Ham Radio - CB - Trail Communications 25
BillyBob82 no antenna=no noise? Ham Radio - CB - Trail Communications 22
J midland glass mount antenna to any cb Ham Radio - CB - Trail Communications 2
J antenna/coax question Ham Radio - CB - Trail Communications 3
storlied Antenna Size? Ham Radio - CB - Trail Communications 55
storlied Lets see your antenna Ham Radio - CB - Trail Communications 5
E 3rd Gen CB / Antenna set ups please show. Ham Radio - CB - Trail Communications 11
storlied antenna grounding ?s Ham Radio - CB - Trail Communications 19
T CB/PA/Antenna Help Ham Radio - CB - Trail Communications 1
H Antenna Choise Problem Ham Radio - CB - Trail Communications 4
T Antenna brackets Ham Radio - CB - Trail Communications 6
Paraphoe CB and antenna install pics Ham Radio - CB - Trail Communications 17
O Whip antenna help Ham Radio - CB - Trail Communications 1
M CB antenna... Ham Radio - CB - Trail Communications 32
Maniak antenna location confusion.. Ham Radio - CB - Trail Communications 7
Paraphoe Running antenna coax into cab? Ham Radio - CB - Trail Communications 31
K tuning antenna in Albuquerque Ham Radio - CB - Trail Communications 8
A Antenna ?!? Ham Radio - CB - Trail Communications 4
Y CB Antenna Q Ham Radio - CB - Trail Communications 10
B CB Radio & Antenna Ham Radio - CB - Trail Communications 22
X mounting a lil willie antenna roof mount style Ham Radio - CB - Trail Communications 6
L Folding down the antenna... Ham Radio - CB - Trail Communications 13
F CB antenna Ham Radio - CB - Trail Communications 15
F Antenna problems Ham Radio - CB - Trail Communications 5
Similar threads
