Anti Rattle Clips for Brakes
ricklee4570
Virginia
I have a 94 Sport. Had the front end rebuilt, still had a rattle sound when I hit bumps. Went back and had the shop check it out. They said it needed the anti rattle clips for the front brakes. They put them in, it stopped making the noise..........for three days. So, back it went, and they fixed it again, this time it lasted for a week. Im nowhere near this shop now, and I guess Im wondering if this is an inherent problem with these Explorers? If you lightly apply the brakes, all noise stops.
By the way, brake pads are like new.
Crunchy
Ottawa, Ontario
Ranger 03 XLT 4L SOHC 2wd
Do your pads have the shims molded into them? My old pads, the shims rusted away and would rattle like there is no tomorrow. My new pads do it too, but to a far lesser degree, and they have molded shims.
I bought this stuff, comes in a spray can, and goes on blue. It is made to apply to the BACK (non-contact side) of brake pads to fill in all the small imperfections in the pad backing that cause the noise. I was told the noise is the pads rubbing against the caliper when you hit small bumps. Once dried, put pads back on and quite like a church mouse. The amount you need, compared to the amount you get in a can, would probably last you a lifetime of brakes. And it was under $5.
ricklee4570
Virginia
Wow, I will try that! Thanks for the advice.
By the way, besides being very annoying, does it hurt anything when they are rattling away?
Robrt32
Sledge Mississippi
94 Explorer XLT
Mine did the same thing.. The clips fixed the rattle for a while now its right back doing it
Anime
EF YEAH!!
2018 EX Sport Concept
Brake noise depends a lot on the parts you're using. Cheaply remanufactured calipers, loose caliper slide pins, low end brake pads, and low end rotors with thin and flimsy anti-squal plates or clips still add up to a noisy system. High performance brakes actually squeal quite a bit and stop rather poorly until they get really warm.
Most often its the material on the pad or the pad design that causes squeal, though, often being incorrect for the application. (too soft, too hard, wrong useful heat range) If it continues to be a problem, you might want to see about having the pads replaced with something else, perhaps even Motorcraft pads from Ford.
Do you know what brand and model of pads are on there now? Some brands are notoriously noisy, sometime just on particular vehicles, though.
I've used NAPA parts and pads/shoes and they've always been quiet as can be. Even when I wore the pads down to the pins and it was just metal on metal stopping the vehicle. Can't beat that for low noise.
Robrt32
Sledge Mississippi
94 Explorer XLT
I bought the pads from Advance Auto and I didn't have much money so I'm sure they are the cheap stuff........ I will upgrade next pay day and see what that does for me
Tony H
New York, Wading River (that's on Long Island)
'91 Eddie Bauer
I keep hearing about these Rattle Clips. I just saw a picture of them on the NAPA website but at a quick glance I cannot see where they would fit on the caliper to do their job. anyone have a picture of them installed?
FarmTruk Disc brake anti-rattle clips...? Stock 1991 - 1994 Explorers 24
C 1994 XLT Anti-rattle clip & squirrely braking Stock 1991 - 1994 Explorers 14
N Anti Theft System Stock 1991 - 1994 Explorers 1
RustyMacintosh New Chinese heads, using anti-freeze Stock 1991 - 1994 Explorers 8
V Anti-Slosh Module 1994 Limited Explorer Insturment Cluster Stock 1991 - 1994 Explorers 6
F 1994 explorer anti-theft no power Stock 1991 - 1994 Explorers 7
N 94 Explorer anti theft malfunction Stock 1991 - 1994 Explorers 2
M Anti Slosh Module Stock 1991 - 1994 Explorers 2
A Anti Theft Module Trouble, 1994 Explorer Ltd Stock 1991 - 1994 Explorers 28
N 92 X sport anti lock brakes Stock 1991 - 1994 Explorers 3
K diasble anti theft feature on 1993 explorer Stock 1991 - 1994 Explorers 2
R NEED Wiring diagrams Limited anti theft controller module & remote power door locks Stock 1991 - 1994 Explorers 3
J Anti Theft in 1994 Explorer - immobilizer active - HELP!! Stock 1991 - 1994 Explorers 1
T Starts but anti theft light remains on Stock 1991 - 1994 Explorers 1
J 1992 Explorer question on leaking anti freeze Stock 1991 - 1994 Explorers 4
C Increase Range of Factory Anti-theft Stock 1991 - 1994 Explorers 1
M Help! Anti-freeze in over flow tank boiling!!!! Stock 1991 - 1994 Explorers 12
7 Stock Anti Theft, Starting issues Stock 1991 - 1994 Explorers 7
J Anti-Theft mode Stock 1991 - 1994 Explorers 3
C Anti lock brake light comes and goes. Stock 1991 - 1994 Explorers 1
N Factory Anti-Theft Problems Stock 1991 - 1994 Explorers 0
D Anti-theft dash light blinking Stock 1991 - 1994 Explorers 0
R Park Brake & Rear Anti Lock Brake lights on... Stock 1991 - 1994 Explorers 9
I Bleed Anti lock Sys. on 1994 Stock 1991 - 1994 Explorers 8
C 94 explorer anti theft Stock 1991 - 1994 Explorers 15
M anti theft question Stock 1991 - 1994 Explorers 0
T leaking anti freeze - FIXED Stock 1991 - 1994 Explorers 5
R How do you disable the anti theft system on a 94 Explorer? Stock 1991 - 1994 Explorers 6
D 94 explorer anti theft stuck on???..?? Stock 1991 - 1994 Explorers 2
J Anti-Freeze line broke Stock 1991 - 1994 Explorers 4
J Anti Theft Device HELP!!! Stock 1991 - 1994 Explorers 12
E anti lock brakes? WTF? Stock 1991 - 1994 Explorers 9
M Stupid anti-theft Stock 1991 - 1994 Explorers 5
O Rear "Anti" lock brakes Stock 1991 - 1994 Explorers 11
J Anti theft system in explorer 1994 Stock 1991 - 1994 Explorers 8
L Bad Anti-Freeze Or Water Pump? Stock 1991 - 1994 Explorers 4
K 93 Limited Anti Theft Problem Stock 1991 - 1994 Explorers 27
O Anyone use anti seize on their lug nuts? Stock 1991 - 1994 Explorers 50
F Problem with the Rear anti-lock light Stock 1991 - 1994 Explorers 6
CheapThrillEX stock anti theft and disarming Stock 1991 - 1994 Explorers 2
B Dealer installed alarm / anti-theft Stock 1991 - 1994 Explorers 15
F 93 4.0X ATYPICAL valvetrain rattle after repairs Stock 1991 - 1994 Explorers 15
K Rattle from trans Stock 1991 - 1994 Explorers 5
W The Dreaded Rattle Stock 1991 - 1994 Explorers 8
J rattle noise durring acceleration? Stock 1991 - 1994 Explorers 10
I 93 Explorer, Rattle Under Dash Stock 1991 - 1994 Explorers 0
9 liftgate rattle Stock 1991 - 1994 Explorers 4
M Think I found the rattle. Stock 1991 - 1994 Explorers 7
HeavyFoot Odd rattle noise Stock 1991 - 1994 Explorers 11
G spark knock, rattle Stock 1991 - 1994 Explorers 9
Similar threads
