TJ@Steeda
- October 2, 2019
- Pompano Beach, FL
- 2019 Ford Explorer Sport
Did the Steeda sway bar and trailing arms today, not difficult just time consuming. Watch YouTube Nocturnal Performance video on the sway bar install, good stuff. The trailing arms are not too difficult, getting them situated so the bolts go thru is the worst part, lots of lube on the bushings that’s go to the subframe helps. Can be done on ramps without removing the wheels, the bolts have to be torqued under load anyway so as not to preload the bushing. I was unable to torque to factory specs on ramps, 122 ft lbs to the pivot point, 111 ft lbs at the knuckle, so 110 and 100 seem to work well. Truck feels very solid and planted, noticeable improvement in steering response
Sounds like a winner - thank you for your review & feedback!!!
