Any LED Headlights for 2015 Explorer out there? | Ford Explorer Forums - Serious Explorations
Larryboy
Williamstown, WV
2015 Explorer Limited
Wondering if there are any LED conversion kits out there for the 2015 Explorers. Also, anyone know how to adjust the high beams, they'd be great for coon hunting the way they're set now. :eek:
same here, need rec, for better than stock head lights.. 2014 Ford Explorer
Headlight solution
I don't have led headlights, but I replaced the stock headlights with Phillips X-treme vision bulbs. They made a big improvement.
I did HID conversion on my previous 2013 and it was a HUGE improvement.
The procedure for adjusting the headlamps is covered in your manual.
Horizontal adjustment only. The high and low beams use the same bulb so adjusting the headlamp position will affect both.
ok thanks must've overlooked it
