Any one with a 1994 Sport | Ford Explorer Forums - Serious Explorations
Hey there. I am looking for people with 1994 Sports. What do you guys run for tire size? I have a stock one. Just bought K&N filter. Some people have told me that 31's will fit. Do any of you have this? I was told earlier that the biggest I could go is 30's. Need to buy tires before snow starts, so any help would be great. Thanks!
Here's my 91 sport.... It's similar enough, the suspension and all that is the same:
Dead Link Removed
Dead Link Removed
Dead Link Removed
That is 6in of suspension, Skyjacker Class II lift, and a 3in body. Onroad I have 35x12.5x15 Dunlop Mud Rovers and offroad, 33x14x15 TSL Boggers
Pete
RFR2212 nice truck. I will get mine there someday.
Still looking for people that don't have a lift what have 30's or 31's. Which fits? Would love 31's but were told originally that only 30's would fit and 31's wouldn't. Would love to know. Need tires bad! LOL!
Go with the 30X9.50's BFG AT KO's. You won't be disappointed.
I have 31's Dunlop Mud Rovers on stock alloy rims.
At stock height it doesn't rub at all.
You may have a little rub at full turn on the front sway bar. But it's only at low speeds so it's just ennoying, not dangerous.
Hope that helps.
the only thing i would worry about is in the rear. your gonna rub on the sway bar reguardles unless you adjust your stops. but in the rear... i'm not sure i know 95+ sports only have one leaf in the packs. i assume yours does too?? seems like that might let them rub? i have a 4-door but i used those coil over shocks to get just that more room for my 31"s. i dont do a lot of rock crawling or anything but i have never had rub. also take account your gears. 31"s slowed down my 3.73's enough for me to notice but if you had the 3.08's i would not go any larger that 235's
just my $.02:chug:
How do you adjust the stops? I am not that good when it comes to mechanics. Luckly my dad is. If I can tell him what to adjust we can get that done. So needless to say I have no idea on the leaf packs. I don't do rough off roading. I usauly just stick to snowmobile trails to help the club out. They are rough and I need shocks anyways. What are the coil over shocks? I was going to add Blistiens. Any thoughts on this? Thanks
a coil over is a shock with a coil built around it for added weight carring capabilities. i bought monroe sensa-tracs i like them but they are by no means off road shocks. i hear good things about blistiens
the bump stops are easy they are two bolts on the nuckle that you simply screw or unscrew to adjust the amount you can turn the wheel lock to lock
