Anybody added aux reverse lights like this?
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
Curious if anyone has added some extra reverse lights the same or maybe something similar to what's here:
http://www.partscheap.com/2011-2013-Ford-Explore-Backup-Reverse-Lighting-Kit-p/4100.htm
I'm wondering how performs and how it looks when it's not illuminated (hoping its not too obvious).
Thanks for reading.
I haven't read where anyone has installed additional reverse lighting. Some have upgraded the OEM lights with LED bulbs to get more light. It seems that reverse lights usually do little to illuminate the area behind you and seem more like a warning that you intend to back up.
Looks like this might be a good investment.
ieee_raider
Paris, TX
2013 Ford Explorer Sport
Wow... that's a lot of $$.
I bought a set of LED DRL's that I'll be mounting and wiring into trailer hitch reverse wires. $25 mod.
Harley#356
NJ
2013 Explorer Sport
I just did Cree projector LEDs to replace my factory reverse lights and it helped a lot
Torqueranger
99 ford explorer 5.0l
T-1000
Honolulu, HI
2014 Ford Explorer Sport
Hey Harley,
I ordered a set of those Cree bulbs you reccommend and I'll see if that does the trick alone. I'd still love to see these aux lights on somebody's Ex but maybe I'll decide I don't need them.
Are you still happy with the turn signals (second type you tried)? I'm thinking maybe I'll just order those as well if they're still performing as you'd hope since I'll have the housing out anyhow.
Rudsther2435
Yuma, AZ
2013 Ford Explorer XLT
I did, I customized my solution, I tapped them in to the reverse trigger at the reverse light & to the dome light signal with diodes both way so they don't back feed into each other. So they act as both reverse lights and also courtesy lighting with the puddle lights. I used these lights from http://www.ddmtuning.com/Products/HighPowerLEDPanel (1.2 Watt Cob LED). Although they are not listed as waterproof, I have washed the vehicle plenty of times, and the LED panels have not gone out, I've had them on for about 2 months now. These small LED panels made a huge difference!
They are the same ones I used to light up my hood area
Harley#356
NJ
2013 Explorer Sport
I like the idea you have going but I travel to the city alot and I would be worried about blinding people when backing up ....Otherwise I would AUX lights with a switch but make sure you mount the switch in a spot that you can't bang with your leg or something so you don't blind the person behind you and cause accident...
They're far from blinding people. If that's the case, you'd want to drive around with your headlights out too because HID headlights are FAR brighter than any LED reverse light. Plus cities are usually so lit up with street lights and everything else, that bright lights aren't as blinding when the ambient light is pretty bright. The reverse lights would be more blinding on dark country roads where it's pitch black with no street lights, and you're not worried about blinding anyone then....and again, still nowhere near as bright as headlights.
Hey Harley,
The 3rd type I tried lol. The amber 5050 LEDs then the red 5050 LEDs were both a dud, too dim to provide enough contrast against the LED brake lights. The 3rd type I tried was the projector CREE LED turn signal in red and those work excellent. Definitely still recommend them!
dmlns1092
VA
2013 Ford Explorer
Harley,
When you tried the third type, the CREE LED for the rear turn signals, did you still need the resistors? I remember in one of your threads that another member had tried something similar and did not need the resistors.
Harley#356
NJ
2013 Explorer Sport
just posted up in the other thread, I'm not sure on that one. I never unplugged the resistors when I put the cree's in to see if they were still needed. I may try that one night this weekand I'll post up.
ieee_raider
Paris, TX
I didn't need resistors with mine when I put the LED projectors in.
Jake100146
Australia
1996 Ford Explorer
I have a question.
Can I just add an extra wire to the existing reverse light wire going to my added reverse light then an earth?
Without a fuse and all the hassle or will I blow the original fuse?
Thanks heaps guys,
Jake
K Anybody lower a non-sport model lately? Modified 2011- 2019 Explorers - Tuning & Mods 3
S Has anybody ran 20 x 10 wheels on a 2011-up? Modified 2011- 2019 Explorers - Tuning & Mods 2
E Anybody from AZ have an Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 3
D Anybody with exhaust on the 3.5L non-ecoboost... Modified 2011- 2019 Explorers - Tuning & Mods 12
B Does anybody know is smoke tinting the headlights is NOT LEGAL in Canada?? Modified 2011- 2019 Explorers - Tuning & Mods 2
E Anybody have an Explorer Sport V6 Ecoboost in Phoenix? Modified 2011- 2019 Explorers - Tuning & Mods 11
D Has Anybody Installed Weather Tech 2nd Row Mat w/Counsol? Modified 2011- 2019 Explorers - Tuning & Mods 2
E added a 20" Lightbar today Modified 2011- 2019 Explorers - Tuning & Mods 1
B Added Magnaflow today to my 3.5 V6 Limited Modified 2011- 2019 Explorers - Tuning & Mods 7
I 2013 Explorer - Maxliner Floormat Review -- Pics Added Modified 2011- 2019 Explorers - Tuning & Mods 4
Levittown Ford Parts New product added, 2013 Explorer lettering Modified 2011- 2019 Explorers - Tuning & Mods 57
B Anyone added a powered sub to your explorer yet? Modified 2011- 2019 Explorers - Tuning & Mods 4
T What have you added to your 2011 Ford Explorer since you picked it up? Modified 2011- 2019 Explorers - Tuning & Mods 72
M Adding aux power to inside rear of vehicle? Modified 2011- 2019 Explorers - Tuning & Mods 6
F Aux Driving Lights - switch options Modified 2011- 2019 Explorers - Tuning & Mods 5
