anyone have experence with installing center consoles??
AddisaurusMoss
Seattle, Wa
1995 Explorer
Ever since i bought my explorer is hasn't had a center console. i found one on craigslist and tomorrow im removing it from the sellers explorer and installing it in my... as of now i have no clue how ill go about doing it... and advice?
Jstcruz
Deltona, FL
97 Ex XLT & 84 Ranger
There should be a metal bracket kind of thing on the floor in between your seats, and 2 screw holes at the bottom center of your dash where a console would mount. I never heard of an Ex with no center console factory? the provisions to mount it should be there. When you go to take the other one out, you have to lift the cup holders and pocket out, undo 2 screws. Pull the cup holders off the back of the console by removing 3 screws and I think a couple holding it to the floor. Then just sit in the back seat and pull the console towards you and It should just pop out.
Thats how mine went anyway :D There may be a couple more screws holding it to the floor, but you dont have to take the whole thing apart to get it up.
vroomzoomboom
Elite Canuck STOCK SUCKS!
selkirk, manitoba
98 supercharged 347 sport
is it a short console, or full length? turdle did a write up on how to remove a full length on a while back. so a search on it, and he has step by step instructions, and pictures as well
P anyone with SOA rear using fox shocks? Modified 1995-2001 Explorers 0
P anyone replace rear shackles with sliders? Modified 1995-2001 Explorers 1
Greg_DonWindsor Anyone still making/selling coilover brackets? Modified 1995-2001 Explorers 23
1 Anyone using a Tweecer for tuning? Modified 1995-2001 Explorers 16
B Anyone run 255/85 16's? Modified 1995-2001 Explorers 2
boominXplorer Has anyone swapped to hydroboost? Modified 1995-2001 Explorers 8
J Has anyone done a dana 44 IFS swap? Modified 1995-2001 Explorers 8
P anyone with a 4" superlift and SOA combo? Modified 1995-2001 Explorers 14
1 Anyone in NJ/PA/NY area ever wheel in Rausch Creek? Modified 1995-2001 Explorers 1
M Anyone out there recommended for tuning 5.0 Explorers Modified 1995-2001 Explorers 1
M Has anyone made quick-removal doors like Jeep Wranglers? Modified 1995-2001 Explorers 5
J anyone know of a more powerful ac blower? Modified 1995-2001 Explorers 2
M Has anyone done a newer Ranger front end swap? Modified 1995-2001 Explorers 2
R has anyone used the speedchanger device or any other device for 01-newer swap Modified 1995-2001 Explorers 0
ZWilson07 Anyone Removed Factory EGR from 5.0? Modified 1995-2001 Explorers 1
4pointslow Has anyone broken a driveshaft? Modified 1995-2001 Explorers 20
A Can anyone tell what company made this brush guard? Modified 1995-2001 Explorers 1
D Has anyone swapped a manual trans into a 98 Expo 5.0? Modified 1995-2001 Explorers 1
J Has anyone tried this? Modified 1995-2001 Explorers 4
H Anyone done a 1997 Explorer 2wd 5.0 conversion into an 04 4.0 Ranger 2wd? Modified 1995-2001 Explorers 0
A Anyone else install an hourmeter? Modified 1995-2001 Explorers 5
1 Rebel Racing wheels... anyone ever used them? Modified 1995-2001 Explorers 3
N Anyone have an electric fan on their 5.0 explorer? Modified 1995-2001 Explorers 53
M anyone have a clue how to remove this lug nut? Modified 1995-2001 Explorers 15
M Has anyone made recessed storage in back quarterpanel void space area? - help Modified 1995-2001 Explorers 5
B Anyone recognize this Explorer? Modified 1995-2001 Explorers 5
zachow3 Supercharger anyone? Modified 1995-2001 Explorers 47
T Does this belong to anyone here? Modified 1995-2001 Explorers 2
M Anyone running lockers or posi/ ls in front and rear? Modified 1995-2001 Explorers 0
G Has anyone here rebuilt a 5.0 Explorer motor? Modified 1995-2001 Explorers 0
E Anyone have any experience with this intake? Modified 1995-2001 Explorers 13
P Anyone know if you can use a F150 signal stalk? Modified 1995-2001 Explorers 1
0 Has anyone installed the billet bumper insert on their 99-01? Modified 1995-2001 Explorers 3
G anyone in nc Modified 1995-2001 Explorers 14
S anyone cram 2 batteries under hood? Modified 1995-2001 Explorers 22
S Anyone use arb donaldson head? Modified 1995-2001 Explorers 9
M Has anyone done this? Modified 1995-2001 Explorers 7
P Anyone found a usable off the shelf 3" tailpipe? Modified 1995-2001 Explorers 6
S anyone done this? sas question Modified 1995-2001 Explorers 0
S anyone done this? Modified 1995-2001 Explorers 0
M anyone know whats up with torque monster headers Modified 1995-2001 Explorers 9
D Anyone have an aftermarket alarm? Modified 1995-2001 Explorers 13
D anyone have or know anything with in DASH gps ? Modified 1995-2001 Explorers 8
J Anyone know how to make my 99 v6 fast? Modified 1995-2001 Explorers 94
F anyone selling 4" susp. lift for 96 explorer Modified 1995-2001 Explorers 0
MidnightRebel07 Anyone completely remove the A/C Compressor and just block off the lines? Modified 1995-2001 Explorers 3
jjaganashi Anyone here with full hydro steering? Modified 1995-2001 Explorers 4
J anyone have 10.5 inch cobra r's on their rig Modified 1995-2001 Explorers 2
S Anyone have a 98' 4r70w valvebody on the shelf? Modified 1995-2001 Explorers 3
MidnightRebel07 2000 grille/ headlight swap on a '97 Mounty, anyone do this? Need info ??? Modified 1995-2001 Explorers 4
Similar threads
