Anyone have the pinouts for 02-03 Premium Radio Sub woofer? | Ford Explorer Forums - Serious Explorations
jrford
Birmingham, MI
'10 Sport Trac
If anyone can help thanks!
I have the ’04 FSM and Wiring service manuals but I need to find the ’03 or ’02 (or black plug Audiophile Radio) wiring diagram for the Sub-Woofer out of the Radio. Seems in ’04 the Base Radio is World Plugs, while the Premium had Phase II.
I have an ’03 Audiophile Radio with black connectors, the two big harnesses plug into the existing ’04 base harness no problem , but I need to add the wires for the Subwoofer. I have a connector for the Radio and the Sub Amp but I want to be sure to wire it correctly, don’t want the smoke genie to escape.
Are these the same in ’03?
’04 Phase II the Pinouts are for the C290c Connector Grey:
Pin 1-Sub High+
2-Sub High-
3-Shield
4-Audio Unit Sub Enable
’04 Sub Side is C466 Connector Grey:
Pin 1 – Sub Enable
2 – Ground
6- Volt Batt
7-Radio High+
8-Radio High-
I found it online but i hate to buy something if i'm only going to use once.
By the way if anyone needs a copy of the '04 let me know i'll be happy to send the page or so to you. Its hardcopy.
Jim
Tricky it swapped in World Plugs (Black) Phase II (Grey)
OK for a World Plug Sub Pinouts Radio Side C290c Black ('03 FSM)
1 BN/OG SUB-
2 LB/RD SUB+
3 SHIELD
4 RD/BK Enable/Mute
I did find something close on line put it didn't have the pins on the Radio side.
Can this be checked with a multimeter? I'd like to know so I can add the sub-out to hook my amp to that and use the rear speaker wires to well.. the rear speakers...
