Anyone Know Gear ratio for rear diff in 1991 Mazda Navajo LX automatic Trans??
91MazdaNava
Davis, CA
'91 Mazda Navajo
Does anyone know/can anyone tell me? Not with the vehicle/can't look at door tag
410Fortune
River Season
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
It could be 3.27, 3.55, 3.73, 4.10 or 4.56 from the factory
No way to know without being with the truck
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
That’s crazy, I never knew 4.56s were a factory option.
410Fortune
River Season
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
Special order only, but they are out there,
MrQ
Smokey the clutch is; Missed shift you did
Moderator Emeritus
Location
Humid, Damp, and Hot
Houston, TX
'98 EB, '93 Limited
First gens only had 4 options, 3 for 4wd.
3.08 (2wd automatic non-limited slip only), 3.27, 3.55 (most common), and 3.73. The last 2 could be either open or limited slip rear.
4.10's we're not offered until 2nd gens. And 4.56's, hell, that would have to be a very special order from the factory.
S pics of the gear selector indicator?? anyone Stock 1991 - 1994 Explorers 6
J 1992 Explorer Transmission problems going into GEAR sometimes "Help Anyone?" Stock 1991 - 1994 Explorers 13
J Has anyone's mom or sister bought one of these... Stock 1991 - 1994 Explorers 3
I anyone rebuilt the A4LD- i need some advise Stock 1991 - 1994 Explorers 1
I is anyone here from texas? Stock 1991 - 1994 Explorers 0
A Anyone know geometry of 1992 explorer frame rails and front beams Stock 1991 - 1994 Explorers 2
T Anyone near Brantford Ontario selling their EX? Stock 1991 - 1994 Explorers 0
O Anyone Know Where To Get Factory Style Seatcovers For A Gray 92 WLT 4X4 Stock 1991 - 1994 Explorers 5
L Does anyone know what the AC high and low side pressure should be on a 94 Explorer? Stock 1991 - 1994 Explorers 16
S Has anyone swapped out the front end 4WD for 2WD front endconversion on a 1st gen Ex? Stock 1991 - 1994 Explorers 3
S Anyone know the secret to getting new manual tranny/t-case knobs seated all the way? Stock 1991 - 1994 Explorers 7
S Anyone know where this little screw goes? Stock 1991 - 1994 Explorers 7
A Did anyone bought their heads from this company Stock 1991 - 1994 Explorers 9
V Anyone know the length of the L rear steel brake line? Stock 1991 - 1994 Explorers 0
V Anyone replace the TTB pivot bushings Stock 1991 - 1994 Explorers 24
M Firestone Destination A/T - Anyone use these? Stock 1991 - 1994 Explorers 17
M Dana 35 - Does anyone know if there is a washer under radius arm stud.... Stock 1991 - 1994 Explorers 2
T Multifunction switch pinout anyone? Stock 1991 - 1994 Explorers 0
D Does anyone have a 1994 explorer that came with a manual transmission? Stock 1991 - 1994 Explorers 20
9 Anyone live in Hampton roads area Virginia? Stock 1991 - 1994 Explorers 1
S Stock alarm on '93. Anyone recognize the module? Need to program new button... Stock 1991 - 1994 Explorers 2
spinnn anyone know window motors Stock 1991 - 1994 Explorers 4
C has anyone had a happy ending after head gasket job Stock 1991 - 1994 Explorers 10
T Can anyone tell me where they think this leaks coming from? PICS INCLUDED Stock 1991 - 1994 Explorers 3
S anyone in or near Raleigh NC?????? Stock 1991 - 1994 Explorers 1
M Anyone every rebuilt their rear differential? Stock 1991 - 1994 Explorers 32
M Anyone else here pile on the miles on their Explorer?? Stock 1991 - 1994 Explorers 6
C Anyone ever heard of this? Stock 1991 - 1994 Explorers 13
C Anyone know what plug this is for? Stock 1991 - 1994 Explorers 6
J anyone know what this wire is for Stock 1991 - 1994 Explorers 6
J anyone know the nut size on the positive terminal of the 94 starter Stock 1991 - 1994 Explorers 3
L To anyone dreading a plug and wire job Stock 1991 - 1994 Explorers 1
T Has anyone found stock 4.10's? Stock 1991 - 1994 Explorers 8
1 Has anyone used the Gabriel Load Carrier Shock on the 1st Gen? Stock 1991 - 1994 Explorers 4
doonze A/C-Heat intake vent??? Anyone....Anyone....? Stock 1991 - 1994 Explorers 20
K does anyone ever put there spare on? Stock 1991 - 1994 Explorers 39
P Help! Anyone have the full text for this TSB!?! Stock 1991 - 1994 Explorers 6
M anyone need this stuff? Stock 1991 - 1994 Explorers 49
P Anyone know about these codes?!?! Stock 1991 - 1994 Explorers 4
K Anyone have there front seats rubbing... Stock 1991 - 1994 Explorers 2
shadowless127 If anyone is interested in a really low mileage 94 XLT 4dr Stock 1991 - 1994 Explorers 9
M Anyone in Alberta want to trade? Stock 1991 - 1994 Explorers 3
K Has anyone experiensed this? Stock 1991 - 1994 Explorers 6
A Anyone know how to test a wiper motor? Stock 1991 - 1994 Explorers 10
N Anyone smell gas sometimes? Stock 1991 - 1994 Explorers 24
3 black smoke, miltiple obd codes, anyone of your guages not working? Stock 1991 - 1994 Explorers 2
M Does anyone know how to fix cracked dash Stock 1991 - 1994 Explorers 8
W Does anyone have trouble with body rust? Stock 1991 - 1994 Explorers 16
S Anyone ever use Rotella Synth 5w-40 oil? Stock 1991 - 1994 Explorers 2
D Looking to buy a 94 eddie bauer, can anyone answer these Q's? Stock 1991 - 1994 Explorers 12
Similar threads
