sehaare
- October 25, 2008
- Chicagoland, IL
- 98XLT 4WD SOHC,94XLT gone
98 SOHC 4WC XLT. From some research it looks that ford changed this fittings at some point. My car has what I think is the older metal styled quick disconnect fittings for the fuel filter. I got the old fitting off with some effort but the inlet fitting o-rings were shot and I ended up with one hell of a fuel spray.
Has anyone used the Doorman kit that is supposed to replace these?
https://www.autozone.com/fuel-deliv...or-800-054/238623_116457_0?searchText=800-054
I saw a YouTube video and the guy on there used one but said that the barb would not fit into his flexible hose section and he had to cut the hard line and use rubber fuel line to make the connection. I was wondering if anyone here had used them and if they had different luck with the barb fitting?
Here is a link to the Video, but I warn you that the language he used was exactly the same words that this old Retired Navy Senior Chief would have used.
Thanks in advance
Thanks in advance
